Tue, Nov 12, 9:40 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 9:05 pm)
Subject: Car Paint Revisited
  • 1
  • 2
templargfx ( ) posted Mon, 30 January 2006 at 10:03 PM ยท edited Tue, 12 November 2024 at 8:07 PM
Ok, many of you would have seen my old car paints, well, I've started again from scratch using a more realistic way of doing things. Tell me what you think of the result so far
TemplarGFX
3D Hobbyist since 1996
I use poser native units
167 Car Materials for Poser
SamTherapy ( ) posted Mon, 30 January 2006 at 10:07 PM
Very nice.
ellocolobo ( ) posted Mon, 30 January 2006 at 10:57 PM
Really like it!
Foxseelady ( ) posted Mon, 30 January 2006 at 11:07 PM
I really like it, but what are the little bumps or grooves I see on the front corner and along the bottom front? Is it just my monitor, hard to tell if I'm seeing things or not when it comes to textures lol. Awesome colors and reflections ext
templargfx ( ) posted Mon, 30 January 2006 at 11:09 PM
there are no textures used here. its all procedural. I think what you are referring to is the compression artifacts caused by having a low quality on the jpg
TemplarGFX
Acadia ( ) posted Mon, 30 January 2006 at 11:47 PM
I like it :)
Tucan-Tiki ( ) posted Tue, 31 January 2006 at 1:07 AM
much better, Look at that wax job:)
Tucan-Tiki ( ) posted Tue, 31 January 2006 at 1:22 AM
can you use this and make into a texture that can be tiled on the outside of the wheel as a mat file and bump?
Tucan-Tiki ( ) posted Tue, 31 January 2006 at 1:26 AM
can you use this and make into a texture that can be tiled on the outside of the wheel as a mat file and bump? --------------------------------------------------------------------------------
Tucan-Tiki ( ) posted Tue, 31 January 2006 at 1:29 AM
outside of the tire.
Tucan-Tiki ( ) posted Tue, 31 January 2006 at 1:44 AM ยท edited Tue, 31 January 2006 at 1:47 AM
Those bumps and groves are from him compressing his jpg image.
One more question how would you gpo about doing a uv map on four tires without effecting the body of the car? can you just map four tires in uv mapper on the mesh without touching the uv mapping of the cars body?
I do know each wheel would need a box uv edit to have 6 sides of a cube as uv zones in which you would only use 5 of 6 uv zones because you wont need to see the other side of the tire. But how can you do this in uv mapper without deconstructing the mesh?
Message edited on: 01/31/2006 01:47
templargfx ( ) posted Tue, 31 January 2006 at 2:32 AM
well, these cars that I am using are actually split into many MANY seperate objects. when imported into poser, poser of course does not split up the obj file into the seperate objects, but as far as uvmapping is concerned, you could load the tyre in by itself. as it happens these cars already have the tyres mapped the way you want them. theres the white-wall section, and the tyre tread section.
TemplarGFX
templargfx ( ) posted Tue, 31 January 2006 at 2:34 AM ยท edited Tue, 31 January 2006 at 2:37 AM
heres another car with another color on. you will notice that poser has failed to import the crease grouping for smoothing out the object, so some areas have gone a little funky.
another things that truly sucks about poser is the "holes" ray-trace elements get in them. if you look at the reflections on the car body, you will notice some small spots that have no reflection on them. I have not, thus far worked out a way to get around this. On the Murcielego at the top, changing the creasing angle fixed it, but not on this car :( EDIT : Tukan-Tiki I think it would be easier to create an image in photoshop to do the bump mapping, as the image you have supplied is not suitable for proper bump mapping, becuase it is a lit object, and not an elevation map of the object. also, for tyre tread, using displacement would yield much better results, but the displacement map would have to be very clean.
Message edited on: 01/31/2006 02:37
TemplarGFX
Angelouscuitry ( ) posted Tue, 31 January 2006 at 2:52 AM
Are these materials available anywhere? Could you show us some screenshots maybe?
templargfx ( ) posted Tue, 31 January 2006 at 3:19 AM
this is the scene that these renders are done in. the big ball is 100% ambient white, and about 4 times the size of the car. and about 4 times the hieght of the car above the ground. the white plane is also 100% ambient white, and sits just below the ground plane (which is used as a shadow catcher) this is a well known trick used by the pro's when rendering cars to give it a nice shiny sharp reflection. Ill take some screens of the material and post it soon
TemplarGFX
templargfx ( ) posted Tue, 31 January 2006 at 4:22 AM
Heres a mini in pink! LOL as you can see looking at this compared to the lambo at the top, the quality of the model greatly effects the quality.
TemplarGFX
RedHawk ( ) posted Tue, 31 January 2006 at 4:46 AM
Very Nice! I can't wait to see the material set-up for this!
<-insert words of wisdom here->
jjsemp ( ) posted Tue, 31 January 2006 at 4:54 AM
Samhain74 ( ) posted Tue, 31 January 2006 at 5:10 AM
These paints are absolutly gorgeous.I expecially like the pink/purple mini.Not the colour,just the look of it,very realistic i think.
xantor ( ) posted Tue, 31 January 2006 at 5:12 AM
templargfx ( ) posted Tue, 31 January 2006 at 5:37 AM
OK, a little change to the way the reflections work. like real reflections, the intensity of the reflection (how bright it is) dictates how visible the reflection is. for example, if your standing in the shade with half your body in the shade, and the other in the bright sunlight. looking at the can paint, you will see the reflection of the side of you that is lit by the sun alot more vividly that you would the side in the shade. does that make sense!?
TemplarGFX
templargfx ( ) posted Tue, 31 January 2006 at 6:39 AM ยท edited Tue, 31 January 2006 at 6:42 AM
Ok, here is what I have so far.
things that still need tweaking :
All of the MATH nodes to do with the reflection amount need tweaking to give good results over a broad spectrum of paint colors.
Math node in relation to basic paint color dark area needs tweaking.
reflection base amount.
I will keep posting updates as I go, feel free to copy this and do your own work on, just post your results! EDIT : If your wondering why this is a little blury, I have just recently re-installed windows, and I dont have any jpg editing applications, so I screen capped this, brought it into mspaint, cut out just the material, then used it as a background in an empty scene in poser, and rendered that scene LOL
Message edited on: 01/31/2006 06:42
TemplarGFX
Robo2010 ( ) posted Tue, 31 January 2006 at 7:45 AM
Now this is a BM.. :-)
x2000 ( ) posted Tue, 31 January 2006 at 8:06 AM
Very cool, thanks for sharing:)
Angelouscuitry ( ) posted Tue, 31 January 2006 at 11:31 AM
Bravo, this is definately of the highest quality rendering! I can't wait to see more!
Samhain74 ( ) posted Tue, 31 January 2006 at 12:15 PM
artnik ( ) posted Tue, 31 January 2006 at 12:31 PM
bookmark
7/8'sIrish ( ) posted Tue, 31 January 2006 at 3:53 PM
bookmark
Robo2010 ( ) posted Tue, 31 January 2006 at 6:02 PM ยท edited Tue, 31 January 2006 at 6:02 PM
Not like anyone would paint a Military Aircraft this color, but I was curious using the nods. :-)
Message edited on: 01/31/2006 18:02
templargfx ( ) posted Tue, 31 January 2006 at 7:00 PM
You should add a 100% white ambient sphere above the plane, out of picture (about 2xplane size) to give it a nice reflection. or use a skydome to get sky reflections
TemplarGFX
Angelouscuitry ( ) posted Tue, 31 January 2006 at 7:01 PM
templargfx - One suggestion, I wouldn't use rendered backgrounds. These images look so real I would love to see them with actuall photographs in the Bkg! Did you get my IM? = )
slinger ( ) posted Tue, 31 January 2006 at 7:23 PM
Hey, templargfx, how am I supposed to get any sleep when people like you keep giving me new toys to play with? I'm trying a "blend" node in place of the "simple_color" and feeding the "simple_color" to one input, and a "spots" node to the other in seach of a metal-flake effect now...with limited success so far, but it WILL work :) Dammit, I pulled an all-nighter coding PHP last night, I don't need this. ~lmao~
The liver is evil - It must be punished.
templargfx ( ) posted Tue, 31 January 2006 at 7:27 PM
The reason I ended the color on a simple color node is for one reason : A simple color nodes is really another diffuse slot. you can plug anything into the simple color node, such as a blend node, and make a whole new material off it. just set it to white first. Ill do up a flake effect when I get back (going to the shop) and we can compare results! Angelouscuitry : yes I did, I am going to zip it up and upload it to my server, its less than a meg (very simple scene) and post the link here when I get back!
TemplarGFX
7/8'sIrish ( ) posted Tue, 31 January 2006 at 7:51 PM
templarqfx and slinger can you guys post your flake effect here when done? -thanks
nakamuram ( ) posted Tue, 31 January 2006 at 8:11 PM
Online Now!
Great work, especially with the chrome!! But I like your old stuff too!!
templargfx ( ) posted Tue, 31 January 2006 at 8:58 PM
heres a nice pick of the lambo on the back of a lowboy truck trailer. unfortunately, the truck model was very low res, and as a result has problems with smoothing (as I still cant get poser to import smoothing groups, even though the feature is supported!) As you can see, on the truck alot of surfaces have textures on them, all I did was plug the texture into the SIMPLE COLOR node (set it to white first). The math nodes that are there automatically change the edge-blend colors to match the texture colors
TemplarGFX
Angelouscuitry ( ) posted Tue, 31 January 2006 at 9:47 PM
Honestly it's very difficult to tell your low res models from your high-res, as they all look so nice! Where do these models come from?
templargfx ( ) posted Tue, 31 January 2006 at 9:57 PM ยท edited Tue, 31 January 2006 at 10:02 PM
well,The truck, and is lowboy trailer come from DMI Car Models (along with many MANY of the cars in my collection)
http://dmi.chez-alice.fr/models1b.html
The Lamborghini is also from there, but this particular one is extremely high detailed, and links to another site from DMI, same with the Mclaren, you can grab those straight from this site :
http://www.nmt.ne.jp/~artmagic/models/free_models.htm EDIT : Oh, there in Lightwave 6 format, this could be a problem for people out there without a model converter such as POLYTRANS by Okino (its what I use) If you DESPERATE for one of these models, I will convert it for you, but dont flood me with requests LOL
Message edited on: 01/31/2006 22:02
TemplarGFX
BladeWolf ( ) posted Tue, 31 January 2006 at 11:37 PM
points to above post by Templar I'M DESPERATE!!!! I'll name my first kid after you if can make this work! Hmmm I don't think God wants me to reporduce, so I'll name my next dog after you! JK. Is POLYTRANS by Okino, free or a pay program?
templargfx ( ) posted Tue, 31 January 2006 at 11:43 PM
Its a purchase program, can convert about 100 formats to 100 formats. has fantastic polygon process functions, such as polygon reduction, triangle->guad (coplanar) quad-triangle. object split by material etc.
TemplarGFX
Tucan-Tiki ( ) posted Wed, 01 February 2006 at 1:09 AM
I hope you make a preset texture pack with this this stuff is awesome:)
Casette ( ) posted Wed, 01 February 2006 at 1:56 AM
Fantastic look, I save your settings' pic for reference :)
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
templargfx ( ) posted Wed, 01 February 2006 at 4:32 AM
VROOM VROOM! LOL
TemplarGFX
templargfx ( ) posted Wed, 01 February 2006 at 5:41 AM
What is wrong with the above image?
TemplarGFX
Casette ( ) posted Wed, 01 February 2006 at 6:35 AM
Mmh... the tobacco ad ? :D
CASETTE
templargfx ( ) posted Wed, 01 February 2006 at 6:41 AM
LOL, other than that! With regards to the WAY the car rendered, with particular attention to the material I created and used on the body can you see it? the MAJOR flaw, the HUGE stuff up
TemplarGFX
BladeWolf ( ) posted Wed, 01 February 2006 at 8:23 AM
The Interior of the car is a bit fubar... can see the background through it. Plus the spoiler is also fubar... eesh. Unless that was done on purpose? :) Never know with us 3D nuts. Also, the Air Duct on the roof of the car is rather screwy too. Almost no definition, looks like a pimple in a way. Anyways, do you have the Murcilago's material zones edited from the stock model? If so, could ya post em in freestuff? This would help me out majorly... Seeing as the peep that modeled the car didn't bother to make a logical naming system for his model. Thanks again!
Robo2010 ( ) posted Wed, 01 February 2006 at 8:59 AM ยท edited Wed, 01 February 2006 at 9:10 AM
Umm...using SkyDome. Increased the skydome tiling due to dotty Sky texture. Lighting issues. Realizing their is no skydome light sets. Endless attempts trying to get the sky to reflect on the aircraft, patients running out. :-(
Message edited on: 02/01/2006 09:10
templargfx ( ) posted Wed, 01 February 2006 at 9:10 AM
plug the skydome image into the ambient color, and ramp the ambient amount to 100%. put the diffuse amount to 0%. if your still having reflection issues, plug the skydome image into the diffuse color also, and slowly raise the diffuse amount up.
TemplarGFX
templargfx ( ) posted Wed, 01 February 2006 at 9:12 AM
The bumper bar answer was very close. more importantly, its the COLOR of the bumper bar. if you look over the car, all the white areas actaully have a highlight that is DARKER than the white LOL
TemplarGFX
BladeWolf ( ) posted Wed, 01 February 2006 at 11:06 AM
do I still get a cookie for my observations? :D
  • 1
  • 2
