Sat, Jan 25, 9:28 PM CST
Subject: Import camera mouvement in vue infinite
shadu ( ) posted Thu, 02 February 2006 at 4:52 AM ยท edited Sat, 25 January 2025 at 8:13 PM
Is it possible to import the camera mouvement from outside into vue infinite? I have the data coming from a tracking software and i want them to be apply on the vamera in a scene. Shadu
DMM ( ) posted Thu, 02 February 2006 at 8:46 AM
You'll need to save the camera tracking export as a Lightwave, Maya or 3DMax scene (or whatever 3D application you have) and then use one of the included Vue plugins to import from the 3D application. As far as I know none of the camera tracking software will save to Vue's native format unfortunately.
videodv ( ) posted Fri, 03 February 2006 at 12:50 AM
Attached Link: Link
I think syntheyes has a way to do this, if you check out there site it has instructions on how.
shadu ( ) posted Fri, 03 February 2006 at 5:13 PM
I try the plugin on the CD... And i am stuck at 100 frame transfert between max and vue..... grrrrr.... It is normal? shadu
DMM ( ) posted Fri, 03 February 2006 at 5:19 PM
I haven't used Max, but if it's anything like Lightwave you need to manually tell max what the animation length is. In Lightwave it defaults to 60 frames, it sounds like Max defaults to 100.
shadu ( ) posted Sat, 04 February 2006 at 6:01 AM
find it.... YOu cannot tell the number of frame in the plugin. But the plugin take the number of frame from the render windows... you just have to set the number of frame to render than go back in the plugin and reset it. Shadu
