Mon, Feb 10, 10:04 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 10 9:40 am)
Subject: Stargate, Atlantis
Robo2010 ( ) posted Fri, 03 February 2006 at 10:00 AM · edited Wed, 05 February 2025 at 4:14 PM
Attached Link: http://www.stargate3d.fsnet.co.uk/
For days now looking for a Stargate, Atlantis Prop in Obj format. Their is only one which I could find, but it is in 3dMax. I do not have a conversion utility. I get nervous going site to site getting no where, and sometimes I pick up these pops-ups that go through pop up blocker. Also, never know what my system could pick up from these places. Anyone seen a Stargate, Atlantis mesh around?
If you press on link, then select models. You will see a Atlantis mesh in the works, but when. Would be great for poser.
Message edited on: 02/03/2006 10:01
anxcon ( ) posted Fri, 03 February 2006 at 10:36 AM
uh....poser can import .3ds :)
Robo2010 ( ) posted Fri, 03 February 2006 at 10:46 AM
Yes, Poser can import 3DS, but not max format.
Robo2010 ( ) posted Fri, 03 February 2006 at 10:52 AM · edited Fri, 03 February 2006 at 10:55 AM
Attached Link: http://gateway.outpost10f.com/cgi-bin/gwconduit.pl?recordID=543
Here is the link to the mesh that is in Max format. I Should have been more clear. My apology. The format is in Max, and not 3dsmax.
Click on link...the select "Meshes-New", then you find many Sci-Fi links..Scroll down and you will see "Stargate". Click on that, and you will see the Atlantis mesh in Max format. :-(
Message edited on: 02/03/2006 10:55
anxcon ( ) posted Fri, 03 February 2006 at 12:35 PM
do a search for crossroads its a 3d utility (free) that just converts
mrsparky ( ) posted Fri, 03 February 2006 at 1:47 PM
Robo2010 - sadly on the url you gave, you can't download any models. Theres only some brillant images, it says this in his FAQ... Q - Where can I download your models? A - My models aren't available for download anymore, either from this website or over email, sorry. As for max model conversion - unless you have max installed even deep exploration can't convert them. Seems like Max is like 'a locked format'. Easiest way is get as many max models as you can, then download the demo and convert these to .3ds before the time limit runs out. Or ask a max user nicely. It's a conversion hassle I've been trying to figure out for years :(
bandolin ( ) posted Fri, 03 February 2006 at 2:47 PM
I've got Max8. I'll convert any Max file you guys want, no problem.
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
JunkoH ( ) posted Fri, 03 February 2006 at 3:28 PM
I converted this to OBJ and rendered in P6. Unfortunately it has no materials or textures. It would quite a chore to map it properly (BTW, the OBJ takes up about 20 MB and has 200k polygons)
pakled ( ) posted Fri, 03 February 2006 at 4:34 PM
If you wanted the old one (SG-1)..no problem..;) however, if you want transport rings, I can set you up..;) I have some Stargate stuff on Planit 3d.
XENOPHONZ ( ) posted Fri, 03 February 2006 at 6:10 PM
Attached Link: http://www.newtek.com/news/releases/02-09-05a.html
If I understand correctly, the Stargate Atlantis series itself is chiefly done in Lightwave. As are all of the SciFi channel programs.
You'd probably be able to find a ton of SGA models -- and other series, too -- in LWO format. Many of them for free.
Something To Do At 3:00AM
XENOPHONZ ( ) posted Fri, 03 February 2006 at 6:12 PM
FWIW -- V3 was born in Lightwave, too.
templargfx ( ) posted Fri, 03 February 2006 at 6:13 PM
That city is just BEGGING for poly-reduction. let me try
TemplarGFX
3D Hobbyist since 1996
I use poser native units
167 Car Materials for Poser
Charlie_Tuna ( ) posted Fri, 03 February 2006 at 6:28 PM
Poser can import Max format BUT ONLY if you already have Max on your pc. You got to have a multi thousand $$ program so you can import a free file into a $200 program, sounds weird to me :-
Why shouldn't speech be free? Very little of it is worth anything.
templargfx ( ) posted Fri, 03 February 2006 at 6:43 PM
how exactly can poser import MAX format? I own both programs
TemplarGFX
Charlie_Tuna ( ) posted Fri, 03 February 2006 at 7:00 PM
There WAS a plug in out for it before P5 came out but don't think it was ever updated, you'll have to look around to see if it was.
Robo2010 ( ) posted Fri, 03 February 2006 at 8:51 PM
I didn't care if it needed texturing. I am up for the project. :-)
svdl ( ) posted Fri, 03 February 2006 at 10:10 PM
There was a plugin that came with Poser Pro Pack that allowed you to host a .pz3 in 3DS Max. And a second one to host the scene in Lightwave. There still is such a plugin for P5 (don't know about P6). Reiss Body Studio. About $200 for the Max version of the plugin, the same price for the Lightwave plugin. And I believe there's also a Maya version, but I might be mistaken. A .max file is like a macro. A series of actions in 3DS Max performed on a base object. That's why you need 3DS Max to do something useful with a .max file, and that's why there are no importers/exporters for the .max format.
My gallery   My freestuff
