Wed, Jan 8, 2:00 AM CST
Forum Moderators: Staff
Subject: Reversed Prop
Starlift ( ) posted Sun, 05 February 2006 at 3:53 AM · edited Wed, 08 January 2025 at 1:53 AM
Is there a method or utility for Poser (or other render media using .obj format) to create a mirrored prop? For example, create a Right Shoe prop from a Left Shoe prop.
Casette ( ) posted Sun, 05 February 2006 at 3:57 AM
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
nruddock ( ) posted Sun, 05 February 2006 at 4:32 AM
Most (if not all) modelling programs have mirroring operations.
If you must do it in Poser, have at least PP, and only want to mirror the geometry coordinates and/or UVs about a simple axis, then a Python script could do it.
PhilC ( ) posted Sun, 05 February 2006 at 6:29 AM
Attached Link: http://www.philc.net/forum/viewtopic.php?t=292
A mirror prop tool is included in the Poser Tool Box.
Starlift ( ) posted Sun, 05 February 2006 at 12:33 PM
I searched the link and site, but can't find a source for the Poser Tool Box. Is it available now?
EnglishBob ( ) posted Mon, 06 February 2006 at 6:23 AM
Poser Tool Box isn't out yet - meantime, here's a couple of freebies that will mirror. Spanki's STOMP utility, and Anim8or, a capable free modeller.
jancory ( ) posted Mon, 06 February 2006 at 12:23 PM
stomp works great, make sure the prop is uv-mapped before you mirror it. anim8tor also is real easy to use, but destroys your grouping, so works best for single-group stuff.
lost in the wilderness
Poser 13, Poser11,  Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine!  Win11, I7, RTX 3060 12GB
 My Freebies
EnglishBob ( ) posted Mon, 06 February 2006 at 4:33 PM
Attached Link: http://www.philc.net/PoserToolBox.htm
and... Poser Tool Box IS out. :)
stonemason ( ) posted Mon, 06 February 2006 at 10:43 PM
Phil ..can the mirrored prop be saved to the library?..with a corresponding obj
Cg Society Portfolio
