Ulli
I'm glad you like him!
I never liked the fact that male figures should have 2 hips that needed both to be morphed,also never liked that you could only check/uncheck the genitals on poser and not from the figure itself!
Thanks for the note Jules!I'll see what I can do...
Actually the part you are reffering is something that I want to smooth on Domus,Dork is over-defined in some points...
Attached Link: http://www.renderosity.com/homepage.ez?Who=pitklad&ViewArticle=13905
Hello I made a quick tamplate for Domus... The teeth problem is because at this stage Domus teeth and Tongue are in a position lower than tha head. This untill I make all the expression morphs so that teeth and tongue won't distort during the morphing...Also Domus takes Dorks body Textures however head and all most other parts are remmaped.
Here is a texture I'm making just to test Domus abilities
Domus doesn't takes Dork's textures (there aren't many anyway) but I tried to use the UVS space ass possible for the best results on the smallest size.
So far no problems here apart from those already mentioned.
(Which is perfectly normal for a beta)
Very smooth face geometry. Its hard to believe that the head topology is still the same. Bravo ! ^-^
Thats a pretty nice texture, Pitklad ! Will it be included ?
Im not good at texturing myself, so as he will be custom mapped, Ill be stuck with whatever is out there for him.
Looking forward to seeing more.
stahlratte
It's incredible that Dork could be so smooth from the start with the same polygons!
A basic texture will be included for sure!This one is a test during testing Domus
Andrew I use Photoshop only!
This one was made using only one photo, quite big and clear, nothing final just testing Domus UVS :^)
Indoda I don't have mimic and don't know what is needed so that a figure works on it :^S Maybee someone can help me with this...However as I said I'll remake all the expression morphs so at this moment Domus doesn't have any head morphs...
Attached Link: http://groups.yahoo.com/group/Domus3D/
Hello everyone! Domus 3 beta version is out If you want to help making Domus 3 better,download him,try him and make any comment/suggestion you like! :^)He is available at Domus3D yahoo group
*More info about Domus:
Domus is a figure based on P4Male (dork)
*Some of the new features are:
-smooth face structure totally remade
-Improved UVS in the same concept of all in one map
-Improved joint parameters
-New eye geometry
-New genitals geometry with an on/off switch on the hip
-Planning to do new expressions
I hope your help makes this list longer ;^)
My FreeStuff
