Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
hi dadt!
call it a question of taste.
blond hair and lashes together with dark brows often looks unnatural, and most characters come together with very dark brows.
so the first thing i do with a new character is to take the facemaps and get rid of the eyebrows in p-shop.
A.
Message edited on: 02/06/2006 09:25
amacord, what is this picture of? A Daz Studio preview or render; a Poser preview or render; a Bryce preview (OpenGL, etc) render; or ...? It is unusual (to me, anyway) to see the background through the eye sockets on a Poser figure - I suspect that whatever is causing that is causing the edge transparency on the brows. If this is a Bryce image, I'd say the export/import of the Poser figure has gone wrong.
V3 exported as OBJ from Poser4; imported into Bryce5 (not DAZ 5.5).
On yours I still suspect some corruption to the model during export-import. It doesn't look like a transmap issue - too even around mesh.
The head on the right was exported from Poser with the "Brows Gone" morph set at 0.010. This meant the meshes for the brows were sunk into the head mesh slightly. When rendered in Bryce with a transmap applied, there is a thin line of see-through surrounding the brow.
The head on the left was exported from Poser with the "Brows Gone" morph set at -0.020. This meant the meshes for the brows were mostly in front of the head mesh. When rendered in Bryce with a transmap applied, there is barely any see-through visible around the brow.
If your problem is related to this, the workaround is to ensure the brow meshes don't intersect with the head mesh. Hopefully this is possible without having the brows appear to be obviously floating in mid air.
wow, hey you really tried it! thats the knights cross for you - or whatever medal you prefer....damnit, i started feeling like a ..... loon!
yes, heres my - now our - problem. ive tested v2 this day - same, same....
i had the hope there might be some smart one-click-way,
something like
Q: why are tranparencies not transparent?
A: did you check "blend transparencies"?
you know what i mean?
thank you very much for your engagement,PJF!
A.
Message edited on: 02/07/2006 19:11
