Wed, Dec 4, 12:32 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 03 5:49 pm)
Subject: Poser Merchant Kit Question
shg0816 ( ) posted Thu, 09 February 2006 at 10:05 AM · edited Tue, 03 December 2024 at 8:24 AM
Greetings, I recently bought a merchant resource kit, and I understand that I need an application (which I have) which supports various graphic files. My question after I load a character into Poser 5, how do I apply my newly created texture to that character? Any assistance would be greatly appreciated
wheatpenny ( ) posted Thu, 09 February 2006 at 10:41 AM
Site Admin
You use the material room to load the texture into the diffuse node of the various material zones. (also if you make bump maps load them as well using the material room). Then create a MAT pose for the whole thing so it will load automatically from the pose library next time you use it.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
shg0816 ( ) posted Thu, 09 February 2006 at 10:48 AM
Great!! Thank you!!
elenorcoli ( ) posted Thu, 09 February 2006 at 10:51 AM
okay go into the material room. use the dropper to click on a zone on the head or body. right click in the mat editor and choose new node|2d textures|image map. in the popup, browse to the location of the texure you are gonna use. then wire it from the node to the area called diffuse color. make sure diffuse color color swatch is set to white. then you can hit the plus sign in the library palate under materials to save this mat file. then click on each element in the pic and click the icon now in the mat library to reapply this texture. you can also use the drop down box at the top of the material editor to find the elements. on standard characters you will have to go through this process twice, once for the head and once for the body, so you'd have two mat files to apply numerous times to the numerous zones throughout the head/body. then get face off's real shader and watch it become really incredible. (but don't use the granite displacement setting on it...not so flattering). real shader does some node stuff and will automatically load bump mapping. you can do that yourself also. the mat room is cool and complicated. but real shader will just shoot you through that stuff.
shg0816 ( ) posted Thu, 09 February 2006 at 6:00 PM
I used your instructions, and they were great. Thank you so much!!
