Fri, Feb 14, 1:10 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: .psd Question
Alpha9992004 ( ) posted Thu, 09 February 2006 at 7:06 PM ยท edited Fri, 14 February 2025 at 12:40 PM
I downloaded some tattoos from Pinball24. Freestuff > Click on search & searched for Tattoo. Came across Pinball24's Tattoo sheets that are .psd. .psd is a Photoshop file, he explains in his README.txt after i downloaded it. it also has a Tattoo Sheet.psp (Paint Shop Pro file)I have PSP 10 & Photoshop CS2. He also talks about using layers & exporting it into Poser to be used on your V3 character. ANYWAY, i guess there tube tattoos. How do i use a .psd file or .psp file & tube files for tattoos,wounds,scars,blood ect..... THAX FOR READING!!! HAPPY RENDERS!! Signed - Ben
Acadia ( ) posted Thu, 09 February 2006 at 7:10 PM
I believe you open the figure's texture inside your graphic program, then overlay the tattoo as a new layer on the texture, resize and position as needed. Merge layers and then SAVE AS a NEW file name. Don't save it as the same file name or you will overwrite the original texture. You then use the material room to apply the texture.
SamTherapy ( ) posted Thu, 09 February 2006 at 8:39 PM
Or, there's the non-destructive Masked Overlay method which allows you to add the tattoo directly in the material room without having to mess around with Photoshop.
bagoas ( ) posted Fri, 10 February 2006 at 1:27 PM
Actually you need not merge the layers. Poser takes .psd files as graphic files, irrespective of the layers used, so that method can be non-destructive also. The Poser masked overlay method works fine also. You can use the tile texture to map a small image on a large one.
