Wed, Nov 27, 5:17 AM CST
Subject: P6 Materials into Bryce?
Shadowrogue ( ) posted Thu, 09 February 2006 at 8:59 PM ยท edited Thu, 25 July 2024 at 3:13 PM
Is it possible to export P6 materials from the materials lab into Bryce? I'm guessing the answer is no, but figured it wouldn't hurt to ask. :)
Thanks!
-Mike
Little_Dragon ( ) posted Thu, 09 February 2006 at 9:46 PM
Procedurals won't translate directly. However, it's possible to apply materials to a flat plane, render that, and then save the results for use as a texture map in Bryce.
Phantast ( ) posted Fri, 10 February 2006 at 4:53 AM
  • which loses the P6 specularity, bump, etc. The answer is no, not only for Bryce but also for Vue.
Shadowrogue ( ) posted Fri, 10 February 2006 at 4:02 PM
Okay, thanks for the confirmation. I figured that was the case. I'll try rendering to a flat plane in P6, minus the specularity and bump, and then see if I can add the specularity and bump to the new texture map in Bryce. Would be a great way around the problem. :) Thanks!!!
