The way I've done it before, for a werewolf transformation, is to use two characters, going through the same animations, transposed on top of one another. Set the texture maps on each one separately - sadly, a texture map can't be animated. Then, animate the transparency settings on each one so there's a blend from one model's visibility to the other. But now that stewer mentiones using te blender, I might go back and give it a try using that... :) jonthecelt
Not true, miss nancy... there is a difference between the diffuse colour channel, which most textyure maps are plugged into, and the 2d image map node, which is what stores the actual map info. Diffuse colour and blender nodes, such as the one suggested by stefan, are animatable. The image source channel of an image map, however, is not - once you load an image into it, you're stuck with it throughout the animation. what stewer suggested was that, if you use a blender node, and plug in two image maps (one into each colour channel), then by animating and changing those colour values, you should be able to blend from one image map to the other in the diffuse colour channel - which is something different entirely from trying to change the texture map used in a single node. Hope this make sense - if/when I have the time, I'll try and take some screenshots to make it simpler to see wht I'm talking about. jonthecelt
Message edited on: 02/19/2006 16:33
Is it possible to have the skin texture change inside an animation? Would like to have the character morph between two different characters and have the skin change as well. Thanks
