Sun, Feb 16, 4:14 PM CST
Subject: +++ DG#205 +++ Poser's Other Props (cont'd) +++ Page 11 ...
geep ( ) posted Fri, 17 February 2006 at 2:01 PM ยท edited Mon, 10 February 2025 at 8:35 PM
Hi Folks,
You'll find the first part of this tut, Pages 1-10 right here.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 17 February 2006 at 2:02 PM
cheers,
dr geep ... :o]
edited 10/5/2019
SamTherapy ( ) posted Fri, 17 February 2006 at 2:06 PM
Yay! First in again. :D
Tereesa ( ) posted Fri, 17 February 2006 at 2:24 PM
diolma ( ) posted Fri, 17 February 2006 at 2:34 PM ยท edited Fri, 17 February 2006 at 2:35 PM
"What's a tetra?"
Hmmm - tricky.
I wonder if there's a clue in the number of steps taken to get one?...
Cheeeers,
Diolma
PS: A terahedron is NOT a pyramid, and don't let anyone tell you otherwise!
PPS: - took doc's advice, this post moved from the preceding thread, where it was no longer relevant (and will delete my gloooom post there also).
PPPS: Anyone care to define the difference between a tetrahedron and a pyramid? I could (reasonably easily, but I've been showing off far too much recently, so I'll let someone else shine..). No prizes tho..;-))
Cheers,
Diolma
Message edited on: 02/17/2006 14:35
cherokee69 ( ) posted Fri, 17 February 2006 at 4:00 PM
momodot ( ) posted Fri, 17 February 2006 at 4:07 PM
leather-guy ( ) posted Fri, 17 February 2006 at 4:29 PM
BkMrrrrq
geep ( ) posted Fri, 17 February 2006 at 4:50 PM
What, no prizes? ............. Then, forget it! ;=[
cheers,
dr geep ... :o]
edited 10/5/2019
Casette ( ) posted Fri, 17 February 2006 at 5:10 PM
yup
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
diolma ( ) posted Fri, 17 February 2006 at 5:17 PM
Okey-dokey: I'll reveal the difference between a "tetrahedron" and a "pyramid" Tomorrow. At the earliest:-)) Cheers, Diolma
geep ( ) posted Fri, 17 February 2006 at 5:30 PM
Oh, I can't wait .......... can I have 3 or 4 guesses? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
mathman ( ) posted Fri, 17 February 2006 at 6:15 PM
Hi doc, snuck in the back of the classroom late (:
cherokee69 ( ) posted Fri, 17 February 2006 at 6:18 PM
tetrahedron - any polyhedron having four plane faces pyramid - a polyhedron having a polygonal base and triangular sides with a common vertex OR pyramid Pronunciation (pr-md) n. 1. a. A solid figure with a polygonal base and triangular faces that meet at a common point. b. Something shaped like this polyhedron. 2. a. A massive monument of ancient Egypt having a rectangular base and four triangular faces culminating in a single apex, built over or around a crypt or tomb. b. Any of various similar constructions, especially a four-sided Mesoamerican temple having stepped sides and a flat top surmounted by chambers. 3. The transactions involved in pyramiding stock. 4. Anatomy A structure or part suggestive of a pyramid in shape. tetrahedron Pronunciation (ttr-hdrn) n. pl. tetrahedrons or tetrahedra (-dr) A polyhedron with four faces.
modus0 ( ) posted Fri, 17 February 2006 at 9:14 PM
Tetra - a group of four. In the above case, for tetrahedrons. ;P
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
geep ( ) posted Fri, 17 February 2006 at 9:45 PM
tetra = four
hedron = face
*** POP QUIZ ***
  1. How many tetrahedrons are contained in Poser's "tetra?"
  2. How may polygons (total) are in Poser's "tetra?"
  3. How many "pyramidal" type structures are contained in Poser's "tetra?"
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 17 February 2006 at 9:50 PM
*** POP QUIZ #2 ***
How can you make a true pyramid in Poser?
(hint - you need to use a little bit of Doc's "magic")
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 17 February 2006 at 9:52 PM
*** POP QUIZ #3 ***
What would happen if PeeDee met NaySayGuy?
cheers, (?)
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Bobasaur ( ) posted Fri, 17 February 2006 at 11:24 PM
Yikes I'm late!
Naylin ( ) posted Sat, 18 February 2006 at 2:33 AM
... Sneek ...
ยฏยฏยฏยฏยฏยฏยฏยฏยฏยฏยฏยฏยฏยฏยฏยฏยฏยฏยฏยฏ
ย ย ย ย My Storeย ย ย My Gallery
____
"You have the right to remain silent. Anything you say can and will be misquoted and then used against you."
jonthecelt ( ) posted Sat, 18 February 2006 at 3:40 AM
Pop Quiz #1 answers.... 1) 12 2) (assuming one trianguylar polygon per face) 48 3) 17 Pop quiz #2 answer... Seem to remember you covering this in an ealrier tutorial, though I cant' quite place my finger on it at the moment... seem to remember it had something to do with writing your own obj file, giving it the vertice order - but I could be wrong... Pop quiz #3 answer... Is this a matter/anti-matter kind of question? Or are we looking at genetic compatibility issues here? :) jonthecelt
geep ( ) posted Sat, 18 February 2006 at 7:08 AM
cheers,
dr geep ... :o]
edited 10/5/2019
jonthecelt ( ) posted Sat, 18 February 2006 at 8:07 AM
Ok, I gotta re-evaluate my answers to Pop Quiz 1 now, having looked properly at the tetra... :) 1) 84 individual tetrahedra... which means... 2) 336 polygons (assuming one triagular poly per face)... and... 3) if you're including those made up of multiple tetrahedra, then I'd have to say... 105? jonthecelt
geep ( ) posted Sat, 18 February 2006 at 9:15 AM
cheers,
dr geep ... :o]
edited 10/5/2019
diolma ( ) posted Sat, 18 February 2006 at 10:37 AM
I stand corrected. A tetrahedron CAN be a pyramid. And all these years I thought that a pyramid HAD to have a square base. It doesn't have to. Oh, well, you live and learn.. Cheers, Diolma
RedHawk ( ) posted Sat, 18 February 2006 at 12:28 PM
Markin' de' Book..... ;)
<-insert words of wisdom here->
geep ( ) posted Sat, 18 February 2006 at 3:08 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sat, 18 February 2006 at 5:28 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sun, 19 February 2006 at 10:05 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sun, 19 February 2006 at 12:42 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sun, 19 February 2006 at 4:02 PM
cheers,
dr geep ... :o]
edited 10/5/2019
jonthecelt ( ) posted Sun, 19 February 2006 at 8:50 PM
hmmm... just got an email saying... "Hello Jon, This automated message is to let you know that geep has posted a reply to your message on the Renderosity.com Poser Forum. You can click the link below to read their response: Subject: +++ DG#205 +++ Poser's Other Props (cont'd) +++ Page 20 ... http://www.renderosity.com/messages.ez?Form.ShowMessage=2587560 Regards, Renderosity Staff" So I get here... no page 20 yet... any ideas what's going on? jonthecelt
geep ( ) posted Sun, 19 February 2006 at 9:05 PM
"Hello Jon,
This automated message is to let you know that geep has screwed up again and had to delete his screwed-up reply to your message on the Renderosity.com Poser Forum.
You can't click the link below to read their screwed-up response because the big jerk deleted it.
No Regards, (tis time)
Better luck next time ....... ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Casette ( ) posted Mon, 20 February 2006 at 1:52 AM
mwhaha
CASETTE
lmacken ( ) posted Mon, 20 February 2006 at 4:03 AM ยท edited Mon, 20 February 2006 at 4:06 AM
Attached Link: http://en.wikipedia.org/wiki/Sierpinski_triangle
This is a very cool figure. I could go on at length; but it's 2am on Monday morning (oh, noes). Two quick points:
"The tetrix is the three-dimensional analog of the Sierpinski triangle." As it gets more complex (you're up to a frequecy of 4) the surface approaches infinity, as the volume approaches 0.
As Bucky Fuller (RIP these 20 years!) would have called it; "Our good friend the tetrahedron" is the basis of his Synergetic geometry.
http://www.netaxs.com/people/cjf/fuller-faq-2.html
"The minimal system with the fewest possible points is a tetrahedron -- four points make a primitive volume with an inside and an outside. The canonical tetrahedron has a volume of one."
Message edited on: 02/20/2006 04:06
geep ( ) posted Mon, 20 February 2006 at 5:58 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Mon, 20 February 2006 at 9:22 AM
Hi Folks, If you're not bored yet, you can tune into Page 21 right here. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
