Wed, Feb 5, 1:03 PM CST
Subject: Skull Caps
vulcanccit ( ) posted Fri, 24 February 2006 at 4:38 PM ยท edited Wed, 05 February 2025 at 9:58 AM
I meant to ask in my previous horribly long message, what is the use for the skull cap?
diolma ( ) posted Fri, 24 February 2006 at 4:49 PM
Skull cap is used to save dynamic hair. By applying the hair to the skullcap, the hair can be applied to different figures just by applying the (saved) skullcap+hair. Since I don't use dynamic hair much ('cos the hair room is an area that baffles be completely), skullcaps are not much use to me, but anyway, that's apparently what they are for. :-)) Cheers, Diolma
randym77 ( ) posted Fri, 24 February 2006 at 6:26 PM
Skullcaps can also replace hair. For example, 3Dream's (in the RMP). They have very high quality textures, and look like pulled-back hair.
vulcanccit ( ) posted Fri, 24 February 2006 at 7:21 PM
so a skull cap is basically, if you will, rubber to glue hair on... once the cap is on, then you can move whatever hair you made ON the cap to other figures based on your master figure, such as vikky?
randym77 ( ) posted Fri, 24 February 2006 at 7:25 PM
Yes. You can also save it to your Poser library. That way, you put the hair on any character, any time you want.
It can also help the "look" of the hair. For example, look at the Poser 6 skullcaps (they're part of the dynamic hairstyles that come with Poser). They are colored a brownish color, to help keep the skull from showing through the hair. A properly textured skullcap could be even better.
vulcanccit ( ) posted Fri, 24 February 2006 at 7:31 PM
can a jessie skull cap be used on vicky? or do you have to make one for each figure?
randym77 ( ) posted Fri, 24 February 2006 at 7:36 PM
You can usually fit skullcaps to other figures without too much difficulty. Use the scale, rotate, and translate dials to position and fit it, then parent it to the head.
There are also free skullcaps out there. PhilC has some for V3 and M3, I believe, but they are rather high-res for dynamic hair.
Try downloading Kirwyn's Genesis Hair for V3 from free stuff. It comes with a short tutorial that it a great intro to dynamic hair. And it comes with low-res skullcaps you can use for other hair if you want.
