Fri, Jan 3, 10:01 PM CST
Subject: Clothes Conv, but no clothing is loading issue
Max_Raptor ( ) posted Tue, 28 February 2006 at 9:23 AM · edited Fri, 03 January 2025 at 9:47 PM
Ok, I have probably missed somthing in the "click 3 buttons" auto conversion part. I am converting a V3 top to fit Laura 3, in CC it all looks fine, no errors, I get a new OBJ and CR2 file in the correct folders. I see the new top inside poser, if I click it asks if I want to load the top so Poser sees it just fine. Problem is, it never apears , hourglass tells me it's reading and loading, but no it's just not there ! Help anyone ?
EnglishBob ( ) posted Tue, 28 February 2006 at 10:19 AM
Try importing your converted OBJ into Poser from File > Import > Wavefront OBJ (uncheck all the boxes in the import dialogue). That will tell you if the problem is with the geometry, or with the CR2.
Max_Raptor ( ) posted Tue, 28 February 2006 at 12:06 PM
Looks a bit wrinkled but seems fine, so problem is in the CR2 file you think ?
EnglishBob ( ) posted Tue, 28 February 2006 at 12:32 PM
Most likely. I've never used CC, but I assume the wrinkling is a by-product of the conversion process. If you have a similar garment for Laura, try using the CR2 from that - edit a copy to point at your new OBJ, and see how that goes.
Max_Raptor ( ) posted Tue, 28 February 2006 at 12:35 PM
browsed thru the CR2 file, one thing striking me are references to V3 makeup JPG maps, trying now to use a BLANK Orig character, the shirt is a V3 shirt and I used a V3 with makeup and such ( no morphs though) as the oregin CR2
Max_Raptor ( ) posted Tue, 28 February 2006 at 12:46 PM
Ok think this might be one part of the problem in the new CR2 I get alot of the folowing ":Runtime:textures:HandspanStudios:Laura:Emeli_Body.jpg" } nodeInput "Auto_Fit" { name "Auto_Fit" value 0 0 0 parmR NO_PARM compared to another CR2 of a similar, I find no references to body textures, mind you I am no wiz when it comes to CR2's
Max_Raptor ( ) posted Tue, 28 February 2006 at 12:52 PM
Viola ! that fixed it, I used a blank DONER instead of defaulting to the target char, now I just need to fix the wrinkled fit lol Thanks :)
EnglishBob ( ) posted Tue, 28 February 2006 at 2:30 PM
Sorry I was away, I was eating my dinner. ;) Glad you fixed it!
Max_Raptor ( ) posted Tue, 28 February 2006 at 2:38 PM
food's over rated anyways :) this software seems to have issues with most things, selecting conform garbels the whole thing,, o well back to salt mine
ValleyMist ( ) posted Tue, 28 February 2006 at 4:21 PM · edited Tue, 28 February 2006 at 4:21 PM
Try using either the original Laura character or a similar piece of Laura's clothing as the donor for saving.
Use a blank V3 for the source figure before converting.
As an aside here, for grins, you can use the program to modify or permanently morph a characters .obj file by loading the character in as the clothing file and saving the .obj file. You'll want to backup your obj file before trying this.
Message edited on: 02/28/2006 16:21
Max_Raptor ( ) posted Tue, 28 February 2006 at 4:34 PM
Yes I kinda figured that after a few trials and errors trying to get acustomed to the modifying bits now since the conversions tend to garble some clothes. I will give that a try and see what comes out in the other end lol Thanks
