Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 01 9:20 pm)
This list shows all the actual morphs "installed within" a given figure, in your case V3. Here's how I do: Fire up poser, load V3 and morph it into GND Create a full-body morph, name it whatever you want, say GND2. In your character library, save your model (creates a .cr2 file of your morphed vicky). Fire up ClothesConverter, load your new .cr2 into your destination figure, chose apply destination morph. In the list that shows up, you'll now see the full-body morph your just saved in poser. Select it and hit apply.. done.
Since you already have a cr2 with the morphs applied: Select the first morph on the list to highlight it, then scroll to the bottom of the morph list. Hold down on the shift key and select the last morph on the list, this should highlight all the morphs. Click on OK The morphs don't take very long to load, and your figure should change to reflect the morphs. Use a V3 Blank character for the source figure. Hope this helps.
Gotta ask. Has anyone sucessfully converted the A3/H3 Bodysuits to V3/M3? Does this program REALLY work?
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
I could work around that. I just need to know before I spend me $$$$ if going from A3/H3 upto the V3/M3/FRK/SF is going to be a problem. I would not expect a problem going "downsize". Thanks for the response.
space
