Fri, Nov 29, 10:47 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 7:57 am)
Subject: problem with Clothes Converter 2
skullsbox ( ) posted Tue, 28 February 2006 at 4:10 AM ยท edited Fri, 29 November 2024 at 10:44 PM
thanks to the help of karen1573 I have succeeded in saving my character in the correct extension for Clothes Converter 2.2. After I have opened the program, I have loaded the clothing file(.cr2) and than I have loaded my character (Girl Next Door 2) that previously I had saved in .cr2 extension. But when I apply the command "APPLY DESTINATION FIGURE MORPHS" a long list appears me where I don't find files that brings the name of GND2 or similar. Why appears me a so long list although I have installed only Victoria3, GND2 and Dress (from la vanitof AS shanim)? what can I do? please hel me. thanx a lot!
manubx76 ( ) posted Tue, 28 February 2006 at 5:07 AM
This list shows all the actual morphs "installed within" a given figure, in your case V3. Here's how I do: Fire up poser, load V3 and morph it into GND Create a full-body morph, name it whatever you want, say GND2. In your character library, save your model (creates a .cr2 file of your morphed vicky). Fire up ClothesConverter, load your new .cr2 into your destination figure, chose apply destination morph. In the list that shows up, you'll now see the full-body morph your just saved in poser. Select it and hit apply.. done.
ValleyMist ( ) posted Tue, 28 February 2006 at 5:27 AM
Since you already have a cr2 with the morphs applied: Select the first morph on the list to highlight it, then scroll to the bottom of the morph list. Hold down on the shift key and select the last morph on the list, this should highlight all the morphs. Click on OK The morphs don't take very long to load, and your figure should change to reflect the morphs. Use a V3 Blank character for the source figure. Hope this helps.
dlfurman ( ) posted Tue, 28 February 2006 at 9:08 AM
Gotta ask. Has anyone sucessfully converted the A3/H3 Bodysuits to V3/M3? Does this program REALLY work?
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD space
ValleyMist ( ) posted Tue, 28 February 2006 at 12:19 PM
I don't know about Aiko to V3, I don't use Aiko so I don't have any outfits for her. Here's an automatic conversion from V3 to Aiko LE. It could stand some tweaking, kind of quick and dirty. :-) Doesn't Aiko have a couple of extra groups on the legs? That could cause problems.
dlfurman ( ) posted Tue, 28 February 2006 at 3:29 PM
I could work around that. I just need to know before I spend me $$$$ if going from A3/H3 upto the V3/M3/FRK/SF is going to be a problem. I would not expect a problem going "downsize". Thanks for the response.
MaryK ( ) posted Tue, 28 February 2006 at 3:42 PM
actually it works better upsizing then downsizing. And yes the program does work.
