Is this a new problem or has it happened before, because I had that problem when saving, not to the libraries, but in general. The fix was simple, when I installed it, I forgot to disable my anti-virus softwhere, and it kept some .dll from loading right. I reinstalled with no AV and it was like gold. -Gabe-
I get an odd saving problem in P4 when adding a character to a character library. Basically, when I load the character back from the library, all the joint parameters are messed up. The figure looks like they are in a funhouse mirror. This happens intermittently and is unpredictable. as anyone else come across this? My only solution is to save as a poser document. I also get this in a small way with hair. If I put hair on a figure, then save in a library and call them back, the hair is offset or rotated 90 on the x axis or both. I have tried shutting poser down before reusing the characters so I don't believe its a corrupt environment issue.
