Tue, Nov 12, 7:41 PM CST
Forum Moderators: wheatpenny, Deenamic Forum Coordinators: Anim8dtoon
Photography F.A.Q (Last Updated: 2024 Nov 01 10:53 pm)
Subject: PSP 9 Problems...
UKmac ( ) posted Sun, 05 March 2006 at 2:32 AM · edited Sat, 09 November 2024 at 11:36 PM
Has anyone had this problem in PSP 9? After working on a .tif file and saving it and then try to open a raw file (canon .crw file) in PSP 9 the shot is dark and will not exposure adjust. The only way to cure is to close PSP and re-open it. I got so fed up with happening I've started using Rawshooter to convert the raw files. It will intresting to see if anyone else has this problem. Steve
DJB ( ) posted Sun, 05 March 2006 at 3:33 AM
All I can think is that something else you installed, or a procedure has corrupted opening crw for you, now you should uninstall PSP and reinstall it. Something similar happened to me with Photoshop Elements 3. Fixed when I reinstalled.
"The happiness of a man in this life does not consist in the absence but in the mastery of his passions."
soulofharmony ( ) posted Sun, 05 March 2006 at 3:52 AM
steve.. l have psp9, because its all l need, .and it is in your installation, l use to have the same problem.. you need to re install..!!!! isnt installed properly plus register with psp9..!!!!.... hugssssss !!!!
I Discovered the secret of the sea in mediation upon the dewdrop ... Sand and Foam Gibran
<a href="http://www.soulofharmonyphotographics.org/">Visit My Website</a>
UKmac ( ) posted Sun, 05 March 2006 at 3:57 AM
Nikki, re-installed already twice, and it is registered. But I will try again as it's been a week since last install. I've only just noticed it because I've only just started working in tif format, I use to work with .psp format, but the files just got to big. Thanks Steve
LostPatrol ( ) posted Sun, 05 March 2006 at 12:31 PM
I cant answer your problem Im afraid, but I think that RAW shooter is a better conversion program than PSP9 I know that adds to your work flow, but the you have more control over the RAW However I only ever used the trial version of PSP9 and didnt like the RAW converter, maybe it has been improved since.
The Truth is Out There
danob ( ) posted Sun, 05 March 2006 at 6:21 PM
No its a mystery to me if re-install does not work maybe its a profile thats got corrupted Raw Shooter is best for sure and the new Premium version 2006 is even better and a free 14 day fully functional download Not free like essentials 2005 but worth the money compared to other expensive options.
Danny O'Byrne  http://www.digitalartzone.co.uk/
"All the technique in the world doesn't compensate for the inability to notice" Eliott Erwitt
UKmac ( ) posted Sun, 05 March 2006 at 8:27 PM
Thanks all, Danob, Rawshooter Essentials 2006 is now free, not much different than 2005.
danob ( ) posted Mon, 06 March 2006 at 6:23 PM
Yes but they do a commercial version called Premium thats the one I was talking about
