Wed, Jan 15, 4:59 AM CST
Subject: Getting a ortho map over related terrain?
RyanSpaulding ( ) posted Tue, 07 March 2006 at 7:03 PM · edited Wed, 15 January 2025 at 1:17 AM
Hey guys, I'm having a bit of a problem getting an ortho photo of some ground to go 1:1 over a terrain I have. I cannot get the image to lie perfectly, even over a plane. I've attached an image. The plane is similar in ratio to the image size. Can anyone help me out? Am I missing a mapping mode or is this just difficult to do in Vue?
-Ryan Spaulding
 VueRealism.Com
bruno021 ( ) posted Tue, 07 March 2006 at 7:18 PM
I'm not sure I understand: you want to map the terrain with the texture map we see in the material editor, right? Or you want to map a plane? Are the terrain/plane and image map same size, or have same ratio? I think if you used the object parametric coordinates system, it should fit, since this mode always returns 1.00 You might have to play with mapping modes, maybe faces.
GPFrance ( ) posted Wed, 08 March 2006 at 4:20 AM
Object parametrical works fine. The object's ratio and orientation must correspond to what covers the the map. In this render, the flat base corresponds to the map rectangle. Only a part of it was raised to terrain heigth (in an external program, not Vue, for this one).
RyanSpaulding ( ) posted Wed, 08 March 2006 at 9:33 AM
How odd it works today! Much thanks!
-Ryan Spaulding
 VueRealism.Com
