Sat, Dec 28, 2:00 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 28 1:54 pm)
Subject: Clothing
ardphil ( ) posted Mon, 13 March 2006 at 11:38 AM · edited Sat, 28 December 2024 at 1:55 PM
Hello, I am having a bit of trouble with clothing my figure, which i adapted from Jessi poser 6 preset. So when i do the cloth simulation the clothes dont fit, is there some way i can get around this, or do I have to custom make the clothes? Or could I be using the cloth function wrong? Thanks Phil
Check it out!
PhilC ( ) posted Mon, 13 March 2006 at 11:42 AM
Not sure how best to answer. Could you give a screen shot or a few more details of how the clothes do not fit?
Thanks,
ardphil ( ) posted Mon, 13 March 2006 at 12:06 PM
Here we go,
Check it out!
ardphil ( ) posted Mon, 13 March 2006 at 12:07 PM
And again, the cloth editor didnt work on it
Check it out!
PhilC ( ) posted Mon, 13 March 2006 at 12:14 PM
Is the pose used in those screen shots the same one that was used to generate the cloth simulation in the Cloth Room?
In the Cloth Room what did you have the dynamic cloth set to collide with?
ardphil ( ) posted Mon, 13 March 2006 at 12:51 PM
Yes it was the same pose. In the cloth room I set it to collide with jessi. Do you have to do cloth simulations on a zero pose?
Check it out!
PhilC ( ) posted Mon, 13 March 2006 at 1:07 PM
Attached Link: http://www.philc.net/CC_sampleVideo.htm
Although there will be isolated cases when you do not start from a zero pose, the vast majority of times starting from the zero pose will be the best way to go. The link is to an on screen video tutorial giving a run through of how to use the Cloth Room. It may help to clarify.
ardphil ( ) posted Mon, 13 March 2006 at 1:24 PM
ardphil ( ) posted Mon, 13 March 2006 at 1:39 PM
Wow, I assume you were the tutor in that tutorial.
Check it out!
PhilC ( ) posted Mon, 13 March 2006 at 1:44 PM
Yes but I originally auditioned for the part of the model :)
ardphil ( ) posted Mon, 13 March 2006 at 2:33 PM
Hahahaa :D So are you a graphic designer for a full time job then?
Check it out!
PhilC ( ) posted Mon, 13 March 2006 at 2:40 PM
I used to be a plumber. I now play 3D modeling all day and occasionally folks throw money at me for doing it. Its a tough life :)
ardphil ( ) posted Mon, 13 March 2006 at 2:42 PM
Cool! When I am older and leave school, thats what i would like to do!
Check it out!
PhilC ( ) posted Mon, 13 March 2006 at 2:47 PM
You may want to skip the plumbing part. Its very hard on your back and knees.
BARTWORX ( ) posted Mon, 13 March 2006 at 5:26 PM
This tut rocks !! but i have learn that with a piece of paper under one side of the monitor thats fixed....... Chris
Not used anymore
