Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 29 6:06 am)
Yes it was the same pose. In the cloth room I set it to collide with jessi. Do you have to do cloth simulations on a zero pose?
Attached Link: http://www.philc.net/CC_sampleVideo.htm
Although there will be isolated cases when you do not start from a zero pose, the vast majority of times starting from the zero pose will be the best way to go. The link is to an on screen video tutorial giving a run through of how to use the Cloth Room. It may help to clarify.Attached Link: http://www.philc.net/CC_sampleVideo.htm
This tut rocks !! but i have learn that with a piece of paper under one side of the monitor thats fixed....... ChrisNot used anymore
Hello, I am having a bit of trouble with clothing my figure, which i adapted from Jessi poser 6 preset. So when i do the cloth simulation the clothes dont fit, is there some way i can get around this, or do I have to custom make the clothes? Or could I be using the cloth function wrong? Thanks Phil
Check it out!
