Vue F.A.Q (Last Updated: 2024 Sep 26 4:27 pm)
Curious, because the obj route works perfectly in Bryce (it's the only way available). So converting to obj does NOT change the UV mapping. It can only be something about the way Vue reads obj files. Also, I don't think that what you are seeing is banding in the texture, it looks to me as though the mesh is distorted.
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
As you can see in the linked pic the textures often look wrong with banding and other strange effects. In this pic the banding on the legs is very evident as well as the strange texturing on the stomach...Am I overlooking something simple that needs adjusting??
After posing in Poser I export the figure as an .obj and then import it into Vue. On import I'm prompted to locate the textures, which I do. After I have adjusted lighting, camera position, etc. I then render.
The character in this pic is Lucille for V3...though I have had these strange effects when using various other texture maps ( such as the V3 Hyperreal maps ).
Any help and advice greatfully welcomed!
