Sat, Dec 28, 10:54 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 28 10:36 am)
Subject: Keyboard commands in P6
sonuqueso ( ) posted Sat, 25 March 2006 at 1:12 PM · edited Fri, 27 December 2024 at 7:54 PM
I use the Ctrl D command all the time in Poser... but my finger slipped, and instead of the figure dropping down to the floor, FOG fills the preview window! What did I do and how can i do it again?!?!?
Khai ( ) posted Sat, 25 March 2006 at 1:15 PM
thats Shift+Ctrl+D ;) - Depth Cued...
sonuqueso ( ) posted Sat, 25 March 2006 at 1:16 PM · edited Sat, 25 March 2006 at 1:17 PM
SWEET! Thanx so much! What other commands should i know about??? Is there a complete list somewhere?
Message edited on: 03/25/2006 13:17
Angel1 ( ) posted Sat, 25 March 2006 at 1:19 PM
....Now Bring Me That Horizon....
Send IM | Gallery
Khai ( ) posted Sat, 25 March 2006 at 1:28 PM
if you pop over to Efrontier, they have a Quick Reference Card that lists all the shortcuts.. PDF file in Print and Screen :)
MikeJ ( ) posted Sat, 25 March 2006 at 5:57 PM
Just wait until you want to hit ctrl+e (restore element), but hit ctrl+r (render) instead (R and E are right next to each other, and it's a very easy mistake to make) and have to wait for Poser to go through all its pre-render BS until you can cancel and get back to what you were doing...
R_Hatch ( ) posted Sun, 26 March 2006 at 1:11 AM
Ultra-annoying hidden bonus command!: 0 (zero): step through window modes. This is annoying because it's very easy to trigger by accidentally hitting the zero key after a failed attempt at clicking into one of the edit boxes for a parameter dials. For the curious, it cycles in the following order (starting by hitting zero while in "full port": Four Ports Three Ports - Big Left Three Ports - Big Right Three Ports - Big Top Three Ports Big Bottom Two Ports - Left/Right Two Ports - Top/Bottom Full Port
JHoagland ( ) posted Mon, 27 March 2006 at 9:24 AM
When you go to hit Ctrl-D be very careful your finger doesn't slip and you hit Ctrl-S (Save file) instead! Be careful of switching between display modes: Ctrl-8 is "textured" display, Ctrl-9 is "smooth texture" display, but Ctrl-0 (right next to Ctrl-9) is "Hide all tools". And hitting Ctrl-0 a second time is not "Unhide all tools". :( And keep in mind that some keyboard shortcuts still do not work if you're on the floating Parameters Dial Palette. I reported this issue when P5 was first released and CL (and e-frontier) have enabled most keyboard shortcuts, but be aware that some lesser-used keystrokes still don't work unless you click on the main Poser window to give it "focus". --John
VanishingPoint... Advanced 3D Modeling Solutions
