Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 8:57 pm)
Oh, if only it were that simple! I've left it OVERNIGHT and still it remains frozen. I've come to listen for the warning signals from my computer that it no longer wants to "crunch" that particular file and thus know when to Ctrl,Alt,Del the bugger. File size shouldn't be an issue because I'm using .jpg files for my texture/bump/transparency maps that are saved at low resolution (2 or 3 vs. the 8 to 10 it can be) just to expressly keep the size down. TygerCub (sigh... toodles off to fuss at computer some more)
When you get this kind of hang up, there is little else you can do other then a full shut down, wait a good ten seconds, then reboot the PC. Also, this will sound ridiculous, but sometimes I have to convert the jpg into a pure bitmap and even though it's larger that way, it gets read right away and everything's fine. WTB
Anyone else had this problem? This is a new one to me. I've had trouble lately with it not wanting to render after applying a new texture, transparency map or bump map, but if I shut the program down and retried a few times, it would eventually come back. Now the darn thing won't even make a .bum map at all! It locks up completely! What's with this lock-up trend? I've read several posts in the past, but no one seems to have a clear explanation. 1) Poser is the only program open at the time. 2) I pull up a "clean" figure... one that is preset to be completely white & has worked without problems in the past. 3) I apply textures under the render option in Materials. Apply a skin texture I've used in the past with no problems. 4) Load a black & white texture for the bump map & choose yes when it asks if it should make the .bum file. 5) Wait 6) Wait some more 7) Ctrl, Alt, Del & kill the program 8) Start again, getting more and more frustrated. As I've said before, the longer I mess with this program, the worse the performance seems to get. I'm NOT giving it up, though because I love it too much. This is supposed to be FUN... not aggrevating. Anyone ever come up with a solution to this mess??? TygerCub
