Error type 1 is a "bus error" which should mean that the program tried to access memory which doesn't exist. However, this is very unlikely and much more often a result of a "repair" operation on system level (something goes wrong, the system tries to cope with it, tries this & that & suddenly it misses the last bus home... :-) I don' think it is a hardware problem, most likely lack of memory or a clash with some odd system extension. Have you installed anything recently?
Attached Link: http://www.macintoshos.com/shareware.library/utilities/utilities.shtml
Found my old copy of MacErrors from 1996, and yes it's a bus error.Hmm... as far as I know macally does very proper developing, and I almost can't believe that they produce a bug like this (even if the mouse driver permanently accesses its own extension file, there would be no problem moving the file with the manager). It really sounds like something else running havoc on your system in the background. Can you boot without extensions (eg by holding down the shift key on startup)? You might have trouble running Lightwave etc (because they might depend on certain extra extensions), but you can then do the switch in extension manager. If it still crashes then, it's almost certainly system re-install time...
Attached Link: http://www.poserforum.net/ubb/Forum1/HTML/001887.html
Nice try, Anthony - and don't give up... :-)This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I'm posting this in the lightwave forum too since I mainly get the error every 5 minutes in lightwave 6. I'll probly get a better responce here though. If you know a solution please respond. Thanx
