Sat, Jan 11, 11:53 AM CST
Subject: .MAX to 3DS and into Poser problems
imagist ( ) posted Fri, 31 March 2006 at 8:23 AM ยท edited Sat, 11 January 2025 at 11:47 AM
Hi All I have just got a new model in .max format which poser and Vue cannot import so I used 3dmax to convert the file and when I import it several parts of the model have moved out of place plus the jpeg textures that were with the .max model have not been stored with the file Am I wasting my time with .3ds files or am I doing something wrong
Regards
Keith
xantor ( ) posted Fri, 31 March 2006 at 8:29 AM
You are better to export from max as a wavefront object because the newer 3ds format doesnt work with a lot of 3d programs (not just poser). I usually export from max as vrml format because it keeps the mapping but if you dont have a program to convert the vrml type then you should use wavefront.
imagist ( ) posted Fri, 31 March 2006 at 9:37 AM
Thanks for your reply Xantor and I tried the the wavepoint file but it is not very smooth on some of the surfaces
any ideas
Regards
Keith
imagist ( ) posted Fri, 31 March 2006 at 9:48 AM
Plus I tried exporting as a VRML but the program VUE didn't like that either
Regards
Keith
xantor ( ) posted Fri, 31 March 2006 at 10:35 AM
Did you import the wavefront object with weld vertices selected? That might fix the smoothing problem.
