Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 06 11:30 am)
Anton,
That's the first thing I do with every new version of poser. But just to double-check, I opened P6 a minute ago. I have a completely blank scene - zilch in it, apart from 3 lights and the cameras. I set it in Prefs again, just to make sure, closed and re-opened poser. Then I added a poser cube, went to the material room and crested an image_map node. In Browse, I find 5 toon./pngs listed. The path is
Runtime/texures/toon/toon1.png
This folder doesn't exist in my Runtime, and there are no toon.pngs to be found.
mac Edit - To make sure, I tried Factory and Preferred State. The toons won't go away.
Message edited on: 03/31/2006 18:58
I'm sure this must have been asked before (but a forum search hasn't shown anything). When Poser 6 first loads in it's original opening mode with the James character, five toon textures and the ground default tex are loaded with it.
Obviously, I've now removed the figure from my personal default set-up but how do I remove the toon textures? They appear at every start-up and are not required.
As they occupy valuable real estate on the drop down textures list, how can I get rid of them?
