Mon, Feb 10, 11:30 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Save and load UI
Adavyss ( ) posted Mon, 03 April 2006 at 11:05 AM · edited Mon, 10 February 2025 at 11:29 AM
I'm realy fed up with the dots.
Would it be possible for a Python script:
  • to save the whole UI setting (including port configuration, camera type & position in ports...like prefered state)in a file which I could choose the name (in order to have a choice of different easily recognisable UI settings)
  • to load a file picked from the different saved files.
svdl ( ) posted Mon, 03 April 2006 at 11:55 AM
Might be tricky. Some things are easy (camera positions - SaveLibraryCamera + LoadLibraryCamera will do it, and selecting a camera from script is easy too), but I don't know if viewport configuration is accessible from Python.
My gallery   My freestuff
mkrueger ( ) posted Mon, 03 April 2006 at 1:20 PM
I don't think that's possible, all UI configuration is stored in the files in the prefs folder and they are only read at startup. Even if you manipulate them, you'd have to restart Poser. martin
PoseWorks ( ) posted Mon, 03 April 2006 at 8:13 PM
Try the UI dots.
