Wed, Feb 26, 4:42 AM CST
Forum Moderators: RedPhantom
Subject: Exporting 3ds obj
arrow1 ( ) posted Mon, 03 April 2006 at 4:03 PM · edited Thu, 12 December 2024 at 2:18 PM
Is there any preparation required for exporting Poser figures (PZ3's)as a 3ds or OBJ? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
pakled ( ) posted Mon, 03 April 2006 at 4:42 PM
depends on what you have in mind. Are you going to use them in other programs? alter the model, etc? The main thing I run into is making sure I can find the textures when I reach the destination of said file. Let us know a little more, and maybe we'll be more help..;)
svdl ( ) posted Mon, 03 April 2006 at 7:47 PM
Exporting as .3ds only works when your scene contains less than 64k polygons - in other words, almost never. Exporting as .obj - you probably want to render in another application. The most painful aspect is collecting the textures from the various texture folders, although Poser 6 comes with a neat Python script that'll do the job for you.
My gallery   My freestuff
arrow1 ( ) posted Tue, 04 April 2006 at 2:22 AM
I have an animated P4 figure saved as a PZ3..For some reason it will not import into Vue5I yet V3 and M3 and other figures do! It is an eve 4 figure with a texture.I saved both as a 3ds and an obj and I ended up with dozens of obj's and 3ds's of each object.Can they some how be all grouped together as one figure? Cheers
SAMS3D ( ) posted Tue, 04 April 2006 at 3:57 AM
What happens when you try to import it to Vue5I? Because it should import. Sharen
arrow1 ( ) posted Tue, 04 April 2006 at 5:02 AM
Vue comes up with a notice (see attached) and then crashes.Vue5I is updated to 5.09 and Poser6 has SR2 installed.I have contacted e-on to see if they can help.Cheers
heiro5 ( ) posted Tue, 04 April 2006 at 1:20 PM
I have a couple of thoughts, not sure if any of it is relevant.
Are you trying to import the animation? If so, you need to put the pz3 (or a copy) in your actual Poser folder (for me: c/Program Files/Curious Labs/Poser 5). When you import, it will ask if you want to bring it in as a single mesh or in parts?
Sometimes I export a figure as on obj to import to Vue (I'm using P5 and V4Pro), and I deselect the "Universe" box (I think that's what it's named... the top box) in Poser and then select just the things I want to export. But that's worked pretty much no problem.
Above you're showing an "unsupported jpeg" error, which I only get on certain jpegs -- no idea why -- but usually can be fixed by closing and restarting Vue (damn memory leak).
Those are some of the things I stumbled around trying to work out...
