Mon, Jan 27, 1:29 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Subject: Why does this happen?
moushie ( ) posted Mon, 03 April 2006 at 11:10 PM · edited Mon, 27 January 2025 at 1:22 PM
Why does this happen? I export a single-element prop file (PP) of a room in Poser 4 as an OBJ file, then re-import it without, repeat without any modification whatever. Everything is the same except that the windows which formerly were square holes in the walls of the room are now solid, filled in. Why? What can I do?
Miss Nancy ( ) posted Mon, 03 April 2006 at 11:23 PM
well, it's not a smoothing problem if it's p4. but the way you should re-import such an object (if using p4) is with all boxes unchecked in the wavefront obj import screen.
PabloS ( ) posted Tue, 04 April 2006 at 12:12 AM · edited Tue, 04 April 2006 at 12:13 AM
my guess would be that the square "holes" were filled with a plane with transparent mat (to simulate glass). When you exported/reimported, the transparent material was no longer applied to the model.
Message edited on: 04/04/2006 00:13
moushie ( ) posted Tue, 04 April 2006 at 11:57 AM
Bravo, you're both right! Checking all boxes brings back the TXT and TR options, and then the glass can be made transparent." I am very grateful to you both for taking the thought and the time.
Anthony Appleyard ( ) posted Wed, 05 April 2006 at 6:12 AM
The .OBJ format can't carry transparency info.
