Mon, Jan 6, 3:15 AM CST
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Jan 05 8:10 pm)
Check out the
Subject: Links To Shareware and Freeware Modeling Programs
Teyon ( ) posted Wed, 05 April 2006 at 10:57 AM ยท edited Sat, 04 January 2025 at 1:38 AM
Okay gang. This is going to be the new software resource thread, where we'll keep a listing of freeware and shareware modeling apps on the net. Be sure to mention the type of modeler (polygon based, nurbs, pixol based like ZBrush, etc.).
Teyon ( ) posted Wed, 05 April 2006 at 10:59 AM
Attached Link: Anim8or
Freeware Modeling App: Anim8or Polygon based modeling and animation package.
Teyon ( ) posted Wed, 05 April 2006 at 11:01 AM ยท edited Wed, 05 April 2006 at 11:03 AM
Attached Link: Metasequoia & MetasequoiaLE
Freeware Modeling App: Metasequoia LE Shareware Modeling App: Metasequoia Polygon modeling based application.
Teyon ( ) posted Wed, 05 April 2006 at 11:05 AM
Attached Link: Marble Clay - Warning! SITE IN JAPANESE
Freeware Modeling App: Marble Clay Polygon modeling based application.
Gog ( ) posted Wed, 05 April 2006 at 11:14 AM
Attached Link: http://www.k-3d.org
K-3d, renderman compliant, modelling with Poly, subdivision, nurbs, blob.
Toolset: Blender, GIMP, Indigo Render, LuxRender, TopMod, Knotplot, Ivy Gen, Plant Studio.
Teyon ( ) posted Wed, 05 April 2006 at 11:15 AM
Attached Link: 3D Canvas
Freeware Modeling App: 3D Canvas Versions also available for cost with more features. Polygon modeling based application.
Gog ( ) posted Wed, 05 April 2006 at 11:17 AM
Attached Link: http://www.blender.org
Blender, Poly, Nurbs, Spline, Blob modelling (complete environment - not just the modeller)
archdruid ( ) posted Wed, 05 April 2006 at 11:36 AM ยท edited Wed, 05 April 2006 at 11:40 AM
Attached Link: Wings 3D
Freeware Poly Modeling
"..... and that was when things got interestiing."
Gog ( ) posted Wed, 12 April 2006 at 4:48 AM
Attached Link: http://www.uvmapper.com/
After modelling UV Mapper may be needed too!
anastasis20 ( ) posted Sat, 06 May 2006 at 7:15 AM
Attached Link: http://sharp3d.sourceforge.net/mediawiki/index.php/Main_Page
Sharp Construct
Freeware displacement modelling app
anastasis20 ( ) posted Sun, 07 May 2006 at 8:20 AM
Attached Link: http://www-viz.tamu.edu/faculty/ergun/research/topology/index.html
TopMod
Freeware/open source(?) manifold mesh modeling system
pauljs75 ( ) posted Mon, 22 May 2006 at 8:41 AM
Attached Link: http://www.terabit.nildram.co.uk/tattoo/
Tatoo
3D mesh texturing. Lets you rotate your model around and paint on its surface.
Free for non-commercial use.
Low cost registration otherwise.
Requires a graphics card. Seems to only work with tri based meshes. :glare:
Barbequed Pixels?
pearce ( ) posted Thu, 01 June 2006 at 4:20 AM
Poseray
http://mysite.verizon.net/sfg0000/
This is mainly intended as a utility to allow various 3D model formats to be rendered in PovRay, but it has other uses, for example you can convert a range of 3D formats to OBJ (+MTL), which Poser & Daz fans would find useful. Also corner angles can be set so the aforementioned progs don't smooth the model into a blob.
Lithunwrap
http://files.seriouszone.com/download.php?fileid=198 (but also on various mirrors)
A `donateware' UV mapping tool that preceded Ultimate Unwrap. It's no longer supported by the software's author, but is still available. Can import and export most common formats, so it's a good reliable converter even if you don't want the UV mapping. You can select polys in your model from a flat map or using the Open GL viewer.
