Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2024 Dec 30 1:55 am)
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
Attached Link: Metasequoia & MetasequoiaLE
Freeware Modeling App: Metasequoia LE Shareware Modeling App: Metasequoia Polygon modeling based application.Attached Link: Marble Clay - Warning! SITE IN JAPANESE
Freeware Modeling App: Marble Clay Polygon modeling based application.Attached Link: http://www.k-3d.org
K-3d, renderman compliant, modelling with Poly, subdivision, nurbs, blob.----------
Toolset: Blender, GIMP, Indigo Render, LuxRender, TopMod, Knotplot, Ivy Gen, Plant Studio.
Attached Link: http://www.blender.org
Blender, Poly, Nurbs, Spline, Blob modelling (complete environment - not just the modeller)----------
Attached Link: http://www.uvmapper.com/
After modelling UV Mapper may be needed too!----------
Attached Link: http://sharp3d.sourceforge.net/mediawiki/index.php/Main_Page
Sharp ConstructAttached Link: http://www-viz.tamu.edu/faculty/ergun/research/topology/index.html
TopModFreeware/open source(?) manifold mesh modeling system
Attached Link: http://www.terabit.nildram.co.uk/tattoo/
Tatoo3D mesh texturing. Lets you rotate your model around and paint on its surface.
Free for non-commercial use.
Low cost registration otherwise.
Requires a graphics card. Seems to only work with tri based meshes. :glare:
Poseray
http://mysite.verizon.net/sfg0000/
This is mainly intended as a utility to allow various 3D model formats to be rendered in PovRay, but it has other uses, for example you can convert a range of 3D formats to OBJ (+MTL), which Poser & Daz fans would find useful. Also corner angles can be set so the aforementioned progs don't smooth the model into a blob.
Lithunwrap
http://files.seriouszone.com/download.php?fileid=198 (but also on various mirrors)
A `donateware' UV mapping tool that preceded Ultimate Unwrap. It's no longer supported by the software's author, but is still available. Can import and export most common formats, so it's a good reliable converter even if you don't want the UV mapping. You can select polys in your model from a flat map or using the Open GL viewer.
Okay gang. This is going to be the new software resource thread, where we'll keep a listing of freeware and shareware modeling apps on the net. Be sure to mention the type of modeler (polygon based, nurbs, pixol based like ZBrush, etc.).
