Wed, Nov 27, 11:57 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Can't get "Average Weld Tool" to do anything but cause Hexagon to crash.
socalkdl ( ) posted Thu, 06 April 2006 at 9:42 PM · edited Wed, 27 November 2024 at 11:08 AM
I don't know about the rest of you, but I cannot get two halfs of a head I've made with symetry to join at the center seam as per the Hexagon PDF help files or in the tutorial in Mike de la Flor's book Carrara 5 Pro Handbook. I select both halves, choose the Average Weld Tool and, viola!, two heads with a gap down the middle! I've tried increasing the value of the tool distance past .10, but it doesn't stick. Sometimes Hexagon just flat-out crashes.
Patrick_210 ( ) posted Thu, 06 April 2006 at 10:26 PM
Looks like there is way to much separation for that tool. It only works at a fairly small distance I think. One way to fix it is to delete one side. Then select just the edges of the symmetry seam. Then set the size for that width to 0.00. It will be easy to know which dimension to set at zero because it will be the smallest one. After your seam has a zero size width, then create the symmetrical copy and weld the two halves together.
socalkdl ( ) posted Thu, 06 April 2006 at 10:53 PM
I've tried it with the seperation much closer, however I just now got it to work by fiddling until 90% of the points joined. I then used the weld tool to clean up the unwelded points. It is not the most intuitive tool but it does work. I should have joined the halves before I extruded the throat. I think my face had to much complexity along the seams.
socalkdl ( ) posted Thu, 06 April 2006 at 11:08 PM
Tonytrout on the Eovia forum for Hexagon just gave me an excellent way to make sure the points I want to weld are on top of each other. "You get the head nice and square facing you in orthographic view, select all the points on the join, and then in the object properties window set the SIZE to 0 (zero) on the axis perpendicular to the plane,(Hint: you have three (XY orZ) axis to choose from, the right axis to adjust to 0 is usually the one that has the smallest number in ) This lines up all the points, when you duplicate and weld the points are identical and weld. The beauty of this method is that you can accurately join the two halfs even after the centre line ponts have been messed around with. No matter how careful you are especially if you are using soft selections ,the centre line points always seem to get off centre."
Patrick_210 ( ) posted Thu, 06 April 2006 at 11:24 PM
That's basically what I said.
socalkdl ( ) posted Thu, 06 April 2006 at 11:44 PM
Thanks. I think I've got it now. Here's the head joined.
