Sat, Jan 25, 5:38 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: Poser scene into C5 scene?
Gordon_S ( ) posted Thu, 06 April 2006 at 10:35 PM · edited Fri, 10 January 2025 at 7:37 AM
Hi All, Here's what may be a dumb question. I'm looking at my manuals here, and not seeing an answer, though. Is it possible to import a Poser scene INTO a Carrara scene?? Like if I have a desert scene set up in C5, and I want to bring a Poser set into that, how would one do it? Thanks!!
ren_mem ( ) posted Thu, 06 April 2006 at 11:05 PM
What version c5 do you have? Don't know if you can do that w/o transposer. I know you can with it which is in c5pro. That should be a pz3 file. There is a manual on transposer that will help there.
No need to think outside the box....
    Just make it invisible.
Tunesy ( ) posted Fri, 07 April 2006 at 4:49 AM
In C5Pro you can import a pz3 into an existing Carrara scene. You can also import individual figures and props directly from your Poser /character and /props folders. Don't know for sure about C5 with Transposer tacked on.
Tashar59 ( ) posted Fri, 07 April 2006 at 6:26 AM
I've been using it for PZ3/PZZ importing. I'm using C5Pro.
mickmca ( ) posted Fri, 07 April 2006 at 6:29 AM
It works just fine. In fact, I build modules in Poser, then combine them in C5P. It keeps Poser off its knees. M
Gordon_S ( ) posted Fri, 07 April 2006 at 7:09 AM
Yes, I do have C5 Pro. I've been using it to bring in Poser6 scenes and render them. Oh, ho!!! I just figured it out. You open the C5P scene, then use the "Import" function. Duh! Why didn't I try that before? I kept using "Open". Sheesh... So, now I'm wondering how to do it the other way around. Supposing you Import a P6 scene into C5P, and then decide you need a desert scene to support it? In other words, how to get the C5P desert and sky into an already imported P6 scene? Thanks for your help! Gordon
Patrick_210 ( ) posted Fri, 07 April 2006 at 8:18 AM
Same way.
ren_mem ( ) posted Fri, 07 April 2006 at 8:47 AM
You may find you will want to use the other poser formats. Not always an entire scene.
Gordon_S ( ) posted Fri, 07 April 2006 at 9:08 AM
Oh, I see. You just use "Import" again, with a C5P scene. Nice! Thanks for your help!! Gordon
Tashar59 ( ) posted Fri, 07 April 2006 at 9:10 AM
I found that if you open the browser, tab is with the animation palette. You can chose what ever you want and just drag it over to the Scene window.
Gordon_S ( ) posted Fri, 07 April 2006 at 3:49 PM
Oooo. That's slick. Thanks! G.
