Sun, Jan 26, 1:04 PM CST
Subject: Setting Depth of Field in Vue 5
mstnicholas1965 ( ) posted Fri, 07 April 2006 at 12:38 PM ยท edited Sun, 12 January 2025 at 7:45 PM
How do you set up DOF so that a selected item is in focus and the rest of the scene blurs off?
bruno021 ( ) posted Fri, 07 April 2006 at 12:55 PM
With the camera selected in the world browser, click on the "target icon" in the object properties tab. Now link the camera to your object, and click on the little camera icon. Set the % blur you want. You'll notice that a box has been added to the viewports. this box represents the focal point of the camera. Change it by changing the focus parameter in your camera's properties tab, otr move the camera around in the viewports to point more precisely to your object. And don't forget to enable "depth of field" in the render settings, if you don't use any of the preset render settings. Render time will rocket sky high, and if you use Esprit or Easel, you'll notice a lot of noise aptterns. You need a lot ( and I mean a lot) of AA to get rid of the noise.
mstnicholas1965 ( ) posted Fri, 07 April 2006 at 1:35 PM
Thanks Bruno! Works like a charm. You're right though, slows the render down....to....n..o..t..h..i..n.....g!
bruno021 ( ) posted Fri, 07 April 2006 at 2:11 PM
Patience, have you must, young Jedi!
Rokol ( ) posted Sat, 08 April 2006 at 10:52 AM
Attached Link: http://www.dofpro.com/
There is a very good plug-in for Photoshop/Coreldraw etc. There was a link in the backroom but I think the URL has just changed. I get excellent results using a Vue generated depth map. Cuts down on extreme rendertimes!
bruno021 ( ) posted Sun, 09 April 2006 at 8:11 AM
Hey, I had forgotten about this one. Must give it a try someday.
