Mon, Jan 27, 4:38 PM CST
Photography F.A.Q (Last Updated: 2025 Jan 22 8:17 pm)
Subject: Watermarks
DJB ( ) posted Thu, 06 April 2006 at 10:06 PM · edited Mon, 13 January 2025 at 12:48 PM
Attached Link: http://www.tucows.com/Windows/DesignTools/Image/ImageWatermarking/
A question came up about watermarks, and all I could answer was that PSP has the ability to do a watermark, but you still have to register for it to be activated. I found a link that has apps to do watermarking, but would like some more input on it. Has anyone here used any of these? Any tips appreciated.
"The happiness of a man in this life does not consist in the absence but in the mastery of his passions."
solrac_gi_2nd ( ) posted Thu, 06 April 2006 at 10:28 PM
Thanks Doug for the link.
TwoPynts ( ) posted Fri, 07 April 2006 at 8:04 AM
PS has a feature that lets you do that...I've never looked into it overmuch. If anyone knows of a free, cross-platform solution, I'd love to hear about it.
Jack Casement ( ) posted Fri, 07 April 2006 at 11:33 AM
file_337259.doc
I bought a book called The Photoshop CS2 book for Digital Photographers and it had a section on adding watermarks to images. If anyone is interested HERE IT IS ATTACHED.
Jack Casement ( ) posted Fri, 07 April 2006 at 11:40 AM
file_337262.doc
I will try again
Jack Casement ( ) posted Fri, 07 April 2006 at 11:41 AM
Sorry. It doesn't want to open my Word attachment.
Damia ( ) posted Fri, 07 April 2006 at 6:26 PM
Actually, Jack, I was able to open the first one once I saved it. It didn't open if I clicked open, but it opened after I saved it and opened it from my comp. Thanks for the doc. I've thought about this from time to time too.
~Damia~ LeviathanPhotography
danob ( ) posted Sun, 09 April 2006 at 6:56 AM
Hmm I have tried watermarking and fell foul of problems if the images were too small after watermarking a file and then trying to reduce the same image as a thumb common practice for many of us here.. The Canon data verification may be worth looking at if you have a lot of images that you want to protect if you are a Canon user but is rather expensive. There is a new version to cover less Pro spec cameras DVK-E2 Like its predecessor, this kit can verify whether or not a photo is an untouched original. But its use of a Secure Mobile (SM) card reader, instead of an IC card reader, makes it more compact than the previous version. Moreover, the versatile DVK-E2 is able to verify images photographed by the EOS-1Ds as long as they are appended with a data verification image and will work with the 20D
Danny O'Byrne  http://www.digitalartzone.co.uk/
"All the technique in the world doesn't compensate for the inability to notice" Eliott Erwitt
dragonfly2000 ( ) posted Mon, 10 April 2006 at 11:29 AM
For info on Digimarc, the one that is in Photoshop, go to: http://www.digimarc.com/watermark/about/ There are several levels of expense with this service, but it is the most commonly used. The ultimate level here is a usage/web search for your watermark with reporting feature. A concern for many of us fer'shure; I'm trying small file sizes relative to print size, heavy compression helps, but isn't a firm solution, but it is free. One artist I know has a password protected web gallery, and only gives it to brick & mortar galleries, or previous/possible clients [that he's meant in fairs or exhibitions]. Do you make a living off of your artwork like some of us? If so the web has some real obvious benefits, but some terrible drawbacks as we all know. Before I put my art galleries up with my commercial site, i contacted a couple of dozen on-the-web artists about the sales that they generated of the art that was specifically posted. Minimal to none was the reply, but many commissions and/or arrangements to view at a real gallery occured often enough that the risk & expense seemed worth while. Bonne chance !
