Thu, Nov 28, 2:59 PM CST
Subject: Anti-aliasing glow
MarkHirst ( ) posted Sun, 09 April 2006 at 4:53 PM ยท edited Sun, 24 November 2024 at 10:34 PM
I've just wasted another 14 hours or so trying to re-render an image. After the render apparently finishes, a new step begins "Anti-aliasing glow" that I've not seen before. To cut a long story short, Vue has crashed for a second time during this new step and I've nothing to show for all the global warming I've just caused. Is this as a result of choosing a particular material ? I've upped the Advanced Effects slider to try and rid the image of noise to 99% too. Can I opt not to have this step ?
www.CambrianMoons.com
Elminster_ZK ( ) posted Sun, 09 April 2006 at 5:01 PM
if you have a material with a glow property (seen on the last tabe of the advanced material editor) - examples are the stock atmosphere material and the Yellow Glow material - and if you have anti-aliasing turned on for your render, then you will get this step. it shouldn't cause a crash, though, it was probably something else on your computer depriving Vue of ram. Though who knows, it's buggy software. ๐Ÿ˜„
"Walk down the right back alley in Sin City, and you can find anything."
bruno021 ( ) posted Mon, 10 April 2006 at 2:48 AM
Glowing materials can cause crashes when using network rendering, but not when rendering on a single machine. Maybe you should try rerendering, with lower quality settings to see if the crash happens again at the glow AA stage, and then report to Tech support.
MarkHirst ( ) posted Mon, 10 April 2006 at 6:20 AM
I've removed the glowing material from the scene and the latest re-render worked fine. I guess that's something I'll have to avoid in future.
bruno021 ( ) posted Mon, 10 April 2006 at 6:56 AM
Contact tech support, this issue was supposed to be fixed, and apparently, it's still there, just like negative lights that still don't work. (although I know for sure they are fixed in the upcoming 5.10)
