Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 17 8:56 pm)
Yep, dead easy.
Open the texture you want to apply the belt to in Photoshop or PSP, depending on your weapon of choice.
Make a new layer.
Paint the belt.
The next bit assumes you're using P5/P6
Discard the skin texture and flatten the belt.
Save the belt.
Make a bump map.
Save that.
Then, using the "masking" technique in the Material Room, you can apply the belt and bump to any texture you choose.
As the title says, I'd like to know how to make a second skin belt that I could apply to Aiko. I'd also like to know if it's be possible to put a bump map on the belt map thing to make it look like its popping out like a real belt would.
