Wed, Feb 12, 11:32 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 10 2:36 pm)
Subject: Clothes Fit problems (on NGM for V3)
alias59 ( ) posted Thu, 20 April 2006 at 10:06 AM · edited Sat, 08 February 2025 at 12:02 AM
Hi,
I have the NGM for V3 morphs by Posermatic.  When I apply a few of these I then have problems fitting clothes (e.g, the Daz Bikini  top for V3).   I thought maybe morph manager (which I've never used before) would let me put the NGM morphs in the V3 bikini so I could then fit it.    I tried to do that and got confused (that happens to me a lot;-).    So...am I on the right track?  Or is there a better solution?
If I am on the right track....pls help with 'my confusion' in Morph Manager :  I loaded the bikini top CR2, and then found many NGM PZ2 INJs to load. Not sure exactly what to do next.  And...if there is a faster way to add the NGM morphs to all V3 shirt/top CR2s I have.
Thanks
wdupre ( ) posted Fri, 21 April 2006 at 8:48 PM
Attached Link: D-Form Plug-in
you can't apply a morph for a figure to a clothing item, morphs only work on the specific mesh they were created from. If the clothing doesnt come with a morph to fit than you will have to make one yourself. there are a couple of programs that can convert clothing for morphs but none of those will work as smoothly as using magnets to adjust the clothing, so I recommend learning to use the D-Form Plugin, and create your own morphs in the clothing to match the figure.
alias59 ( ) posted Fri, 21 April 2006 at 8:55 PM
Thank you very much...I have D-Form, and the D=Form tutorial/docs so I should be able to get that part working.
I've been looking for info on Magnets..did not find anything at the Daz stie.  Can you give me a basic idea of how I create/apply magnets in DS 1.3?
THanks again.
RHaseltine ( ) posted Sat, 22 April 2006 at 8:25 AM
DForm is the DAZ|Studio equivalent of Poser's magnets.
AestheticDemon ( ) posted Wed, 24 May 2006 at 6:47 AM
To 'put a figure morph into a clothing item' you don't use MorphManager, you use 'The Tailor' by codeTwister, it's in the daz store., It creates new morphs in clothing to match the morphs in the figure.
Plan B - Use Dforms to fit the clothes, then spawn them as morphs (not in ds 1301 - functionality broken, use ds 1201)
