Mon, Nov 18, 12:31 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 17 8:56 pm)
Subject: Aiko's Expressions vanish
Gurichi ( ) posted Thu, 20 April 2006 at 8:20 PM · edited Tue, 13 August 2024 at 2:22 PM
Aiko herself is fine, but what happens is I'll edit her in Poser then save her as a new figure, then when I load her into the posing area  her facial expressions won't work anymore... Does anyone know why that happens and if I can fix it? 😕
FlyByNight ( ) posted Thu, 20 April 2006 at 10:50 PM
When you save her and a box comes up asking if you want to save the morphs as well, do you say yes? If you say no that's the only thing I can think of as to why her expressions might not work.
FlyByNight
xantor ( ) posted Sat, 22 April 2006 at 3:25 AM
If you have poser 6 do you have pmd files switched on?  Try switching them off, but you will need to redo your figure and save it into a library again.
Gurichi ( ) posted Sat, 22 April 2006 at 1:03 PM
Quote - If you have poser 6 do you have pmd files switched on?  Try switching them off, but you will need to redo your figure and save it into a library again.
:blink: I don't even know what a pmd file IS!! But I'll try making my figure again..
xantor ( ) posted Sat, 22 April 2006 at 7:46 PM
In your preferences switch of use external morph targets and try redoing your figure.
LilWolff ( ) posted Sat, 22 April 2006 at 11:56 PM
Quote - In your preferences switch of use external morph targets and try redoing your figure.
I am having trouble with injection morphs not saving in the pz3, could that be caused by this also? Should it be on or off?
xantor ( ) posted Sun, 23 April 2006 at 4:59 AM · edited Sun, 23 April 2006 at 5:01 AM
I don`t have poser 6 but quite a few people have switched off  use external morph targets because it has caused problems.
Switching it off will do no harm but leaving it on could cause problems with figures.
LilWolff ( ) posted Sun, 23 April 2006 at 1:44 PM
Ok thank you for your help. Since is similar problem I saw no need for new post. I have external morph targets off by default, maybe i will try to put it on.
