Vue F.A.Q (Last Updated: 2024 Sep 26 4:27 pm)
Eureeka! Finally a question I know something about! Compatibility mode resets all the settings to the barest basic functionality. That way you can turn them back on one at a time until you find the setting that caused the crash. In your case, it was the power, so you just have to go to options and set them back to whatever settings you had. Because of a bad graphics card, I have to work in compatibility mode so I know what you mean about the display. It's like flying blind! I hope this helps.
If you've made modifications to your Options, the 'Reset options to default' sets the options back to the state they were in when the product was installed. You will still have to 'retweak' them to get them where you want them.
If anyone wishes to see the file, e-mail me.
BTW, here is a render from it. I'm studying architecture. It is my 2nd exam for "Perspectives by computer". We're using Autocad (As I have done for about five years), si I took the model into vue "just to see what happens". I also removed some objects to make VUE perform faster.
guess which one was made in vue?
you're saying CG sunlight is actually based on a real thing????
I was using vue5 Espirit.
Then lights get out. When eectricity returned and I restarted my PC, Vue5 ran on something like "Compatibility mode". Now when I import a model from Sketchup > Max > Vue, it just shows the bounding box of the objects. this is inconvenient since I am doing architectural renderings and can't set a path for animations.
Before the compatibility mode thing, my models imported just fine. Now they don't. Any ideas?
