Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Try returning to only the original fonts that came with your Windows, or go into Start, Settings, Control Panel, Fonts and start looking for that large font that looks like the one Poser is trying to use. Then delete it. Back up your fonts first would be a good idea and be prepared for a long trial and error session if you've installed a lot of new fonts. Windows is not kind when you add new fonts. It can't seem to remember where the default font is. The other possibility is that you've installed Adobe reader and one of the Adobe fonts is responsible...same thing, go into Fonts and delete all the Adobe fonts that it will let you delete. eng
![file_160503.zip](https://live.cdn.renderosity.com/forum/_legacy/file_160503.zip)
My problem is the following: The fonts are too big (well, it seems that it's only one font that this problem appears too! When I, for example, get into the "Animation Setup" (Animation -> Animation Setup...) the following appears: Animation Output Settings: <-- This is ok. Frame: <- this is also ok. But then: W and He is shown. Really too big! (Size 28 something maybe) 640x640 is shown ok. Then furher down, the text Frames Total Hour:Min:S " is shown. Too big! (notice that the 'S' should surely be 'Sec', but it doesn't fit into the window. What to do?" NOTE: I have included some .bmps for you to see so I get what I mean. Thanx in advance! Daniel
