I've had 7 of 9 in my mind as a project for some time, thou someone did do her awhile ago. The eyepiece..and other fixtures..were done on the texture map. A morph is probably not the way to do this as you're stuck with whatever faces are available on the mesh in the area to make it. This should really be done as a prop, which could be built off the head faces to get the right fit. Projects in the works now prevent my starting this up again, but maybe this gives someone food for thought. You pic here IS the best view is this gismo I've seen...
Attached Link: http://members.xoom.com/wulgaru
Don't know if this is possible, but would any of the morph gurus like to try this one?
