Attached Link: Introduction to MorphMaster Pro 2.0
I love it. You work from the CR2, rather than the OBJ as with the free version. Check out the tutorial at the link. It shows some of the tools, and explains the workflow. I'll be doing more when I get the time. Hope this helps :)Oh, and there's a downloadable version.
John
Me too, I like some feedback on that product.
Does the program helps you do like custom morphs?
Very intersting,
jlovesart2
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
When I wrote that I was working on 3DC's Alexa 2, a rebuild of the one that had copyright problems. She was built to resemble her predecesor as much as possible, but was a whole new mesh. Besides that body fit morph, I also did some of the expressions, and all of the phonemes. They are a good example of what it can do.
Consider that the gums, teeth and tongue are not separate groups in a Poser figure, but they do have their own materials. In a morph that opens the mouth, the lower teeth, lower gums, and lower jaw must move as a group, yet the selection of the skin must falloff at a predictable rate, so as not to involve the upper lip too much, etc. If you've ever tried to select vertices through that mess in a modeling app, you can appreciate being able to select by materials, or individual meshes (how just the lower teeth and gums are selected).
I usually used several soft selections on the skin. You have good control of the selections, and you can see which vertices are hard selections, and which are in the falloff zone. Then you use rotate and translate deformers to get your morph.
The real beauty is that you can go back to any step and change the parameters of a selection, or a deformer. And you can save the command stacks, which sometimes make a good starting point for a similar morph.
Would something like that make a useful tutorial? Or do you have an example that would be better? Not that many people are going to be doing phonemes, so I'm open to ideas.
John
Anyone used Morphmaster, available at Daz? They've just released V. 2.5.
I'm primarily interested in morphing clothing to fit morphed Vickys. Thanks for your comments.
http://www.daz3d.com/shop.php?op=itemdetails&item=4196&trid=25144116
Gallery
