Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Sep 17 7:30 pm)
Yea my problem is that these props all worked fine before or I should say the last time I used them and I've just found some more that are doing this as well. It's behavious suggests a virus but I can't find one!!
the fault is also strange, this particular prop is a room made up of several bits, walls. floor, doors etc. and it's only the floor thta shows this error.
I tried completely removing it from the props folder and the geometries folder and the textures and then reinstalled from the original zip and still the same error on the floor prop!
I just don't get it!!
My main fear is that if it is a virus it's going to just eat away at my runtime until all my props go like this!
Injustice will be avenged.
Cofiwch Dryweryn.
Well this particular prop is the "floor" in the "room of secrets". It's an old prop that has worked fine for ages, I've made no changes to Poser that could have caused this!
I have also found the same problem in the DAZ environment "on another night" or something like that it's called yet the cyclorama version of it which came on the same installer works fine!
I'm really stumped as to what's causing this and why!
Cofiwch Dryweryn.
See this post by EnglishBob -> http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2645365#message_2669589
Other than that, :unsure:
Fortunately bought items only occasionally suffer from this problem (in direct proportion to the quality of testing / QA at the store concerned).
Freebies are much more likely to be afflicted.
The easiest way to avoid running into it is to get into the habit of unpacking to a temporary directory and doing a text search on the files for "" (check for absolute paths) and ".bum" check for files referring to BUM files (can be edited to refer to the JPG file if it's supplied).
I've done 3 virus scans that have found nothing, I've deleted and redone my preferences, PMD's are off and I've done a complete uninstall and reinstall and I still get this message on some props that did work fine before.
Cofiwch Dryweryn.
