Sun, Oct 6, 9:06 AM CDT
Vue F.A.Q (Last Updated: 2024 Sep 26 4:27 pm)
Subject: GeoControl and Vue Esprit
Paula Sanders ( ) posted Wed, 03 May 2006 at 3:12 PM · edited Thu, 05 September 2024 at 10:15 PM
Attached Link: http://www.christianfly.com/friends/peten/Vue-geocontrol_en/vue-geocontrol_en.html#requis
I just saw this tutorial on the GeoControl web site forum. It looked very good even though I haven't tried it yet. I have been importing GeoControl generated terrains into Vue 5 Infinite very successfully. It is by Darthmagus who also distributed a free preset which is very nice. In case the link doesn't work, here is the URL: [ http://www.christianfly.com/friends/peten/Vue-geocontrol_en/vue-geocontrol_en.html#requis](http://www.christianfly.com/friends/peten/Vue-geocontrol_en/vue-geocontrol_en.html#requis)
gillbrooks ( ) posted Wed, 03 May 2006 at 5:13 PM
It works very well - I had tried both Zero Edges filter in GeoControl and Vue and found Vue did it much better.  Here's 2 terrains imported into Vue (Infinite not D'Esprit but results are the same)  using that method, both 2048 resolution with very little correction after loading into Vue.
Gill
iloco ( ) posted Wed, 03 May 2006 at 5:58 PM
Paula do you have a link to the free presets or to any free images that we can use in Vue to see how they look. :)
ïÏøçö
gillbrooks ( ) posted Wed, 03 May 2006 at 6:16 PM
Attached Link: http://www.cajomi.de/Forum/
The presets are available in the forum
Gill
Paula Sanders ( ) posted Wed, 03 May 2006 at 6:24 PM
Iloco - Gillbrooks gave you the information I had.
However, I have found that depending how you turn or position any terrain generated in GeoControl will determine your eventual image. What I mean is that I will sometimes generate a terrain that can have more than one eventual image in it. Then,  how I rotate it in Vue (think about the top view) will determine which image I use. So I might construct two images, for example, from one terrain created in GeoControl.
iloco ( ) posted Wed, 03 May 2006 at 7:28 PM
Thanks to both for the information. :)
ïÏøçö
Darthmagus ( ) posted Thu, 04 May 2006 at 5:34 AM
Attached Link: Some images made with GeoControl
You can load a free 30 days demo. Artists presets are available with the registred version.
