Photography F.A.Q (Last Updated: 2025 Jan 30 8:47 am)
LOL..
Is my answer ahahahaha;
The cleaning of optical surfaces, especially those of first-surface mirrors, is the most delicate and exacting task which the astronomer is called upon to perform. At the time of cleaning, a lens is most vulnerable to damage; damage which cannot be re paired. Yet if a telescope is to perform at its greatest potential, cleaning must be done time to time.
I have used the following method for over twenty-five years without adding a single scratch to the surface of my mirrors and lenses. It has the advantage of requiring only materials which are readily available at the neighborhood pharmacy or grocery store. The cost is less than twenty-five cents per cleaning.
First you must realize that usually the best advice on cleaning mirrors and lenses is.........DON'T DO IT. Dirt and grease which are adhering to the surface of mirrors and lenses may degrade image quality, but they will not damage the delicate optical surface until they are moved against it. Removing dirt without allowing it to rub against the underlying optical surface is what makes cleaning such a tricky task. If your mirrors and lenses are so dirty that they must be cleaned, then this is the way to do it:
FOR MIRRORS
This restriction means that the above procedure must be modified. Only the front surface can be cleaned. If you remove the cell from the telescope, you will be in big trouble. There are probably not more than 25 people in the United State s who can effectively collimate a refractor!
Bonne lecture!!!!
LOL but it's thrue ;)
kiss
how so much info, tx for doing the research for me :} I'll def try this was with optision's lens cleaning cloth. I used to use my Adidas sunglasses cleaning cloth to as it is lint free...
Rights Come With Responsibilities VAMP'hotography Website VAMP'hotography Blog
A very instructional and comprehensive guide Valou - Thank You !
No more using my shirt sleeve for me, or the Siamese cat because he has a thin nose and can get into all the corners
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies
live;
Their heads are green, and their hands are blue, And they went to
sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
Attached Link: VisibleDust
Rubbing alcohol is ok, but not real alcohol like vodka, because in can destroy the lens coating.Question the question. Answer the question. Question the
answer...
I wish I knew what I was gonna say :oP
LOL at Richard.You finally found a use for a cat! ;^)
Excellent info.Thanks Valou!
It does not do to leave a live dragon out of your calculations, if you live near him." -- J. R. R. Tolkein
Marlene <")
Marlene S. Piskin Photography
My Blog
"A new study shows that licking the sweat off a frog can cure
depression. The down side is, the minute you stop licking, the frog
gets depressed again." - Jay Leno
I think the 90% is rubbing alcohol, I don't like cotton ball idea either coz then it leaves streeks and lint but as a start it's okay then I'll polish...
Carl Zeiss and others make "lens cleaning cloths" which appear soaked with some alcohol mixture. I wonder how safe are these tissues?
I readily see how pressure when cleaning can be more harmful than any other ingredient. Grit often is not something dissolvable and will simply move around like a grain of sand unless gently removed before any wiping is done. On my lens there is UV filter to cover and protect the lens. A filter may be replaced much more economically than a lens should damage happen!
Valou, I likely ruined my first reflector telescope by rubbing the front surface mirrors.
Neat thread of good information!
hiiii,
I have more info!!!!! LOL
Cleaning Optics
There's a good reason to ignore dirt aside from maintaining peace of mind. A dirty lens or mirror can always be made clean, but a scratched one is scratched forever. Cleaning causes tiny scratches ("sleeks") if you don't do it exactly right, and maybe even if you do. So clean optics rarely. I've washed the main mirror of my trusty 6-inch reflector twice in 30 years, and the mirror of my 12-inch reflector twice in nine years. I've never cleaned the secondary mirrors at all, aside from blowing off dust, and they still look fine -- because I've been careful about clean storage.
Actually, the surface you are cleaning is usually not glass but an optical coating that is softer and more vulnerable. The basic antireflection lens coating is magnesium fluoride, which can be very soft if the manufacturer applied it at too low a temperature. Good magnesium fluoride coatings are usually made quite hard. The newer, better multicoatings tend to be softer but are also being hardened up by manufacturers.
Cleaning a mirror. Ordinary house dust contains bits of rock powder carried in on the wind. Sleeks are caused by rubbing this stuff against glass. So when a cleaning finally must be done, the first and most important step is to remove all grit. Washing a 12-inch telescope mirror. The safest way to remove grit is to blast the surface with tap water. That may be all you need to do. If dirt remains, swish the surface very lightly with clean cotton in lukewarm water and detergent. Rinse with tap water, do a final rinse with distilled water, and set up on edge to dry.
Mirrors (and disassembled lens elements) can be completely immersed in water for thorough cleaning. You'll need the kitchen sink, two towels, liquid detergent, a bottle of distilled or demineralized (deionized) water (available in drugstores), and a package of sterile cotton. (If it's sterile it's more likely to be grit-free.)
Wash out the sink, rinse it well, and lay a folded towel on the bottom. Take off any jewelry from your hands and wrists. Put the mirror face-up on the towel, and with the drain open, blast the mirror's surface with room-temperature water for a few minutes. This will remove most dust and grit safely. Do not shock a mirror's metal coating with hot or cold water.
Turn off the tap and give the mirror a final rinse with distilled or demineralized water. This will leave no mineral deposits when it dries. Stand the mirror on edge (on a folded towel to prevent slipping) and let it dry completely. You can draw off stubborn water droplets carefully with the corner of a paper towel.
If the mirror looks reasonably clean, quit while you're ahead! You can't scratch a mirror you haven't touched.
If it's still cruddy, plug the sink, put the mirror back in on the towel, and fill the sink half full with lukewarm water. Add a teaspoon of liquid detergent and let the mirror soak for five or 10 minutes. Then, holding it underwater, swirl it around for a last chance at rinsing off remaining grit.
Take a wad of cotton and, starting at one edge, swab the mirror in one direction, applying no pressure but the weight of the cotton itself. Grit is less abrasive wet than dry, so do this underwater.
Turn the cotton over in a backward-rolling motion as you go, so that as soon as a part of it rubs the surface, that part is carried up and away from the glass. Throw out the wad when it has been turned completely. The job may take a lot of cotton.
It's a good idea to work in complete silence. If you make sleeks, you may actually hear them! If so, stop and proceed to the rinse.
Drain the sink and run lukewarm water over the mirror for at least a minute. Finish with a rinse of distilled water and tilt the mirror on edge to dry.
Eyepieces and small lenses. For dusting eyepieces, a quick and safe first step is to lay a finger across the eye end (without touching the glass!) and suck air under it past the lens while flipping your finger away. The sudden pulse of air removes much dust. This takes about one second at the telescope.
The traditional method for dusting optics is to brush very lightly with a camel's-hair brush. These brushes, sold in camera shops, have soft bristles with minimum tendency to scrape grit against a lens. The bristles should be untrimmed ("natural end"). Brush very lightly in one direction, while turning the brush in a backward-rolling movement so that as bristles pick up dust they are flicked away from the glass. Seal the brush in its container or in a plastic bag when not in use.
Camera shops also sell cans of compressed gas for blowing dust off lenses. Be careful with the kind that use liquid propellants; these have a reputation for spitting onto the glass and leaving a residue, if the can is tipped or shaken in use. Your own breath is likely to leave spit too.
One convenient lens cleaner is the E-wipe, a lint-free pad soaked with methanol. You drape the wipe on the glass, pull it across once, and discard. The methanol dries in moments, leaving a clean surface free of dirt, oils, or grease.
and it's true!!!
HUGSSSSSSSSSSSSSSSSSSSSSS
For tougher dirt or stains on the surface of a lens, various lens-cleaning solutions are available. Among the simplest and most effective are pure isopropyl alcohol or methyl alcohol (methanol), available in drug stores and hardware stores, respectively. Standard isopropyl rubbing alcohol works well too and is easier to find, but avoid alcohol preparations with other ingredients that may leave stains. If you dilute a cleaning solution, use distilled or demineralized water. Camera shops sell lens-cleaning fluids such as Crystal Clear, which is ultrapure methanol.
You'll need a soft, grit-free wipe. A well-washed piece of pure cotton cloth works well. So does a cotton swab or piece of clean cotton. Moisten it with the fluid and swirl the fluid gently across the lens, applying no pressure. If necessary, rub dry with a fresh piece very gently.
Don't drop liquid directly onto the glass. It's liable to seep into the edge of the lens cell and carry dissolved grime onto interior surfaces, staining them.
Eyelash and fingerprint oil will stain coatings permanently if left on long enough. So will moisture condensation sealed in after observing sessions. (Blow-dry your eyepieces if necessary before capping them.) But such stains are only cosmetic, eyepiece manufacturers insist. They should have no noticeable effect on performance.
An eyepiece's field lens will probably stay clean by itself. Leave it alone except perhaps for an occasional air blast or camel's-hair dusting. If problems develop inside the eyepiece, don't try to take it apart. You are almost certain to tilt and jam ("cock") a lens element. Send the eyepiece back to the manufacturer for disassembly and cleaning, which some makers will do at little or no cost.
Refractor objectives and the corrector plates of catadioptric telescopes should not be taken out of their cells except by an expert. (If you ever do take a refractor lens apart, make sure you will be able to collimate it after putting it back together -- an art known to few. Make sure that on the outside rim of each element is a penciled indication of which sides face each other, which face the sky, and the orientation with which the elements are to be reassembled so that the same points around their edges match up again.)
They can be cleaned the same way as small lenses by using more time and fluid. It's okay to put drops of fluid directly onto the glass as long as none gets into the edge of the cell. Resist any urge to hurry the job.
Dew Hazards
When a lens or mirror gets colder than the dew point of the surrounding air, water or frost will condense on it. A dirty surface will dew up much faster than a clean one. Never wipe a dewed lens or it may sleek -- and more dew will immediately condense on it anyway. Instead, warm the glass slightly with an electric hair dryer. An eyepiece can be warmed in your hand, then dried by sucking air in across the eye lens or by waving your hand just in front of it.
Dewing can be reduced or stopped by shielding the glass from exposure to most of the open sky. Exposure to the chill of space is usually what causes things to dew up at night. If a basic dewcap doesn't do the job, you can add commercial or homemade antidew heaters.
If you get rid of dew reasonably soon, it has no effect on the optics. Stains and worse problems arise when dampness remains, or forms, on optics in storage.
A cold telescope can become dripping wet on being brought into a warm house. Don't cover or seal the telescope until it's completely dry. One school of thought says that sealing is a bad idea altogether. When a telescope is in storage, the humidity in the air that was sealed in can condense onto the optics if the temperature of the glass drops. Dust covers should probably "breathe" a little to let water vapor out during changes of temperature. Cloth might be a better cover than plastic, at least over the eyepiece tube. Of course, avoid a storage site that shows signs of being prone to dampness.
Be vigilant to prevent dirty lenses and mirrors -- and then forget about them. Perfectionists are never happy, but astronomy should be fun. After all, what matters is not what you see on your telescope, but what you see through it.
That I can use 90% alcohol to cleans my lenses with?
