Mon, Dec 23, 2:33 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Dec 21 9:55 pm)
Carrara Free Stuff here.
Subject: Carrara 5 using Hexagon 2 models
steama ( ) posted Sat, 13 May 2006 at 3:43 PM · edited Mon, 23 December 2024 at 2:29 PM
Hi All,
Has anybody been using Hexagon 2 models inside Carrara 5? Specifically Hexagon 2 models using UV Unfold, painted texture mapping and displacement.
If so how has it been working out? Do you find the two application totally compatible at this point?
I am wondering how well these applications are working together as I have seen very little produced with the two applications working together since the Hexagon 2 release. Especially using the new Hexagon 2 features of UV mapping tools, texture mapping and displacement.
Just Curious,
Steama
Patrick_210 ( ) posted Sat, 13 May 2006 at 7:09 PM
The only problem I find is the seam split after applying displacement. It's a known bug and I'm sure they're working on it. Otherwise it seems to work fine.
ren_mem ( ) posted Sat, 13 May 2006 at 7:49 PM
Well, it's been right at 2 weeks since hex2 release so it may take a bit. 😄
No need to think outside the box....
    Just make it invisible.
steama ( ) posted Sat, 13 May 2006 at 10:07 PM
Thanks guys for the response.
That is what I am thinking. I am prepared to wait for version 2.1. I'm sure that will be the ticket.
Patience I guess. I don't want this to be rushed.
ShawnDriscoll ( ) posted Sat, 13 May 2006 at 11:10 PM
So far, with the time I have, I've been able to UV unfold models in Hex 2 after a lot of trial and error and have managed to import the models as OBJ into Carrara 5 with their UV maps imported correctly.
steama ( ) posted Sun, 14 May 2006 at 3:02 AM
Great! What is the great secret Shooner?
Thanks for the reply
steama ( ) posted Mon, 15 May 2006 at 7:33 PM
Finally! I have figured it out!
ShawnDriscoll ( ) posted Mon, 15 May 2006 at 7:41 PM
Yes.  It takes awhile to figure out.  But it is do-able.
ren_mem ( ) posted Mon, 15 May 2006 at 8:02 PM · edited Mon, 15 May 2006 at 8:03 PM
I have found that I forget to validate when using displacement and then lose it so I am glad I have been practicing. You can't get it back with undo either. So if you have beeen working for awhile and then change tools or several other things you can lose it. However, I am getting a bit better with both. UV stuff is never easy tho no matter what you use. There is an art to it.
