Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 11:25 am)
I've printed a few Poser pics and they come out very well....I assume when you render your images in Poser you change the default dpi setting of 72 to something much higher...I usually go for 300 dpi or even higher. Obviously this will increase render times, but is necessary to avoid pixelation as the default 72 dpi is only really intended for screen display and not printing.
“…they are saved as 72 dpi jpegs.”
Jpeg is a “Lossy” format intended for web and screen viewing, but is a poor choice for printing.
Save your work in a “Loss-less” format like Tiff for printing (personally I use PDF).
Also 1200x1200 @72dpi is only giving you a 4x4 inch print at printer resolution (300dpi).
If you are printing larger than that, it isn’t going to look very good.
If you render your image at 2400x2400 @300dpi in Poser, you will get an 8x8 inch print that fits nicely on your size printing paper.
Chuck
“How do I get it to only print 4X4?”
Well to make things less confusing (till you get the hang of print vs screen resolution), you could first change the DPI from 72 to 300 in your paint program.
That doesn’t resize, resample or change the number of pixels … it just changes the math for your printer (1200x1200 is 1200x1200 no matter what the DPI is).
But the software you are printing from, (your paint program or the printer’s software) should have either a “page setup” or “print preview” dialog box where you can adjust the size that will be printed.
Chuck
Anyone else having frustrations printing their poser images? Is there a tutorial out there about how to get a good result?
I've been printing my 1200X1200 images from Photoshop on 8.5X11 Kodak paper using an HP printer. But some of the edges in the image look pixelated.
