Phantast, Do you know what the thread was called regarding wet skin? Also I understand you also posted some information on using magnets,which I cannot seem to find. Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Attached Link: http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2644471
was this the one? the search feature for the forums is really quite useful as a first approach to finding information. type in "wet skin", limit the forums to be searched to poser, leave the date range as is, or if you think the info was posted more than 45 days ago, change the date range, press search -- and presto. phantast's info was in the first hit.The problem with adding drops to the texture is that it doesn't account for gravity. If you're posing your characther lying down, or with the arms up or something... it will look fake.
I have bought a few good wet characters (for M3) but they only work in certain situations.
A shader that actually took the orientation of the character into account would be very cool. Ajax has some various skin types in his Free Shader Pack (I believe it's still here in freestuff) - they're all based on Don (I think) but of course the texture map could be swapped for the one you're using.
I'm sure this "could" be possible, using the P node for example. I'm not good enough using the shaders, but if i remember well, the P node allows to work with the height of an object. So the bottom could be wider than the top.
I'll try to look if there is a way to create drops, but as said, i'm not as good (by far not) as Ajax for example.
And if i remember well, Ajax did a Wet and Dirt shader in his "Shader Pack". It was for Poser 5, but i think it should work with Poser 6, with little adjustment.
That was the one.
But droplets are essential to a proper wet look, and if they are running the wrong way that's too bad. With a lot of work one could rework the pattern so that the drops are running the way you want, otherwise your choices are, either (a) keep your character upright, or (b) hope that no-one will notice (which is quite possible, depending on the degree of closeup).
Some amount of non-realism in Poser is acceptable, in my view. Worse things happen with joints and hair before we start worrying about direction of water flow.
I have real skin Shader.Can anyone assist me with how to put a dirty and wet skin an a V3 figure?
