You don't have to load them all. The supplied INJ pose with the character you are using will find them and load the correct ones.
Probably the only time you would need to inject them all is when you're creating your own characters. I keep a fully loaded set of characters for this purpose.
No idea. Probably.
Create a subfolder and put all your other pose stuff in there. That's what I did, anyhow. Don't know about finding stuff in other Runtimes. I think it may have some trouble. I have a full set of INJ/REM poses in all my Runtimes.
Yes, AFAIK, they are one and the same.
Not quite, as I understand it. The morph channels are already present in the characters which support INJ, in the form of empty "slots".
Hi,
Just a follow up.
I've looked a bit more closely at some INJ files, and I now understand that the INJ PZ2 files include readscript's with paths for the morphs, so I guess that answers part of my question.
However, I also looked at some FC2 files, and they seemed to just set the values of dials and not inject anything. There were only lines of the form
targetGeom Asian1
keys
k 0 0
In that case, so I either have to look through the FC2 file and make sure I manually inject all the required INJ PZ2 files, or do a INJ ALL?
Thanks!
Helmer
Hi everybody,
I'm a newbie who's still trying to find my way around.
I've bought many characters who say that they require the head and body morphs for the base figure. Does that mean that I have to manually load all of them using the inject all poses, or does it mean that the inj files that come with the character will go looking for those inj morphs on my hard disk and load the required ones?
If inj files don't require me to load all morphs, is there any situation I actually would want to load all, other than once to just see what morphs are available?
Is there any annotated list of the DAZ head and body morhps? Some of the names are a bit cryptic.
The DAZ h&B morphs all clog up the beginning of my pose folder with ther ! names, and I understand that I must leave them there, so that other injection files can find them. I put all my downloaded content into Poser 6Downloadsruntime, and I believe that other inj files in that runtime should have no problem finding the DAZ files. However, I also bought 'Ultimate Head Morphs for mIKI1020' and 'Ultimate Body Morphs for Miki'. Their instructions tell me to install them in the default runtime. Will files in my downloads runtime find morphs in the default runtime?
By the way, is Miki1020 the same as Miki?
Is it correct to say that inj files load the morp channels and set the values while mor files set values for morphs that have already been loaded?
Thanks!
Helmer
